PB110 Sunny Excellent was fitted with L-series OHC engine L14. This L14 engine was the third L-series design after the L13 (Aug 1967), L20 (Nov 1967) & L16. At 1428 cc, it was essentially a de-stroked L16, having the same bore, but a new reduced crankshaft stroke, which was longer than the L13 but shorter than the L16.
PB110 was fitted with L14S (single carburetor engine).
- 85 HP
GX models used L14T (twin carburetor engine).
- 95 HP
These were pulled from the Datsun Bluebird 510 parts bin, with some modifications.
- 510: L13 engine (1967) Applied Model Codes 210-218
- N510: L14 engine A86,A88-A89
- P510: L16 engine 219-222
- H510: L18 engine A87,A94
Nissan Part Numbers Applied Model Codes:
- 122: SP310
- 210: 510-S
- 219: P510
- 220: P510-TK
- 230: PL510
- A08: 510 ('69)
- A35: P510 ('69)
- A49: P510S ('70)
- A51: P510TK ('70)
- A87: H510TK
- A89: N510T
- A92: 510 2-dr Automatic
- H23: B110GTK (GX 4-speed Sedan)
- H25: KPB110 ('71)
- H27: KPB110GR ('71)
- N04: (K)P510(A)TK ('71)
Rocker Cover
'Datsun OHC'
- 13264-A4900 COVER ASS'Y-rocker L14S
- Same as 510 L14, L16 except SSS [1970.8 catalog]
- Same as later L13 cover
- differs from early L13 cover
- 13264-A5100 COVER ASS'Y-rocker L14T
- Same as 510 L16 SSS [1970.8 catalog]
Cylinder Head
Single Carb
- 11041-H2510 HEAD ASS'Y-cylinder L14
- 11041-H2511 HEAD ASS'Y-cylinder (from '73-4) L14
- 11041-H2512 HEAD ASS'Y-cylinder (from '73-7) L14
Twin Carb A87 = H510TK
- 11041-21901 HEAD ASS'Y-cylinder L14T
- Same as 510 L16 SSS, CSS
- 11041-A8712 HEAD ASS'Y-cylinder (from E# L14-098246) L14T
- Same as 510 L16 (from '72) which replaced all former L16 heads
- 11041-A8713 HEAD ASS'Y-cylinder (from '73-5) L14T
- 11041-A8714 HEAD ASS'Y-cylinder (from '73-7) L14T
Camshaft
- 13001-21000 CAMSHAFT L14S
- Same as 510 L14
- 13001-H2700 CAMSHAFT L14T
- Same as all later 510 L16S single carb (except LPG) [1974.3 catalog]
Intake Manifold
Single Carb
- 14002-A8901 MANIFOLD ASS'Y-intake
- 14002-A8903 MANIFOLD ASS'Y-intake
- 14002-A8925 MANIFOLD ASS'Y-intake
Twin Carb
- 14002-22026 MANIFOLD ASS'Y-intake
- 14002-N0400 MANIFOLD ASS'Y-intake
Exhaust Manifold
Single Carb
- 14004-A3500 MANIFOLD-exhaust
- Same as 510 L14
- Same as later 510 L13 (from E#/L13-187492)
- Same as later 510 L16 (from E#/L16-95967)
Twin Carb
- Same as single carb engine
Carburetor
Single Carb
* 16010-A8900 CARBURETOR ASS'Y-auto choke (213282-211) L14S (M/T) * 16010-A9200 CARBURETOR ASS'Y-auto choke (213282-231) L14S (A/T)![]()
Twin Carb
- 16010-H2710 CARBURETOR ASS'Y-twin (HJL 38W-5) L14T
- 16554-H2710 JET-needle L14T
- 16346-12210 SPRING-suction L14T
Air Cleaner
Single Carb
- 16510-A0800 AIR CLEANER KIT
- 16500-A8901 AIR CLEANER ASS'Y
- 16500-H2306 AIR CLEANER ASS'Y
- 16500-H2500 AIR CLEANER ASS'Y (from '72-6)
- 16500-H2505 AIR CLEANER ASS'Y (from '72-6)
Twin Carb
- 16500-H2700 AIR CLEANER ASS'Y (up to '71-9) [thin oval]
- 16500-H2710 AIR CLEANER ASS'Y (from '71-10) [fat oval]
