Release Bearing
Revision as of 03:58, 28 April 2011; view current revision
The clutch Release Bearing is often called the throwout bearing and is operated by the clutch Release Lever.
release bearing, throwout bearing
  • Bore = 1.5748
  • Outer Diameter = 2.8898
  • Width = 0.752
Bearing and spring are same: B110, B120, B210, B310 regardless of engine or transmission type. RHD and LHD are the same.
  • 30502-21000 BEARING-CLUTCH RELEASE
    • SKF N2106,N3048 $32
    • BCA/National 01576 $21.89
    • Timken DNB01576C $22
The bearing was originally designed for the Datsun 510 model series (part code 210), so fits many Datsuns, basically most RWD model with A-series, L-series, Z-series, KA-series or VG-series engines.
  • 1971 - 1973 Datsun 1200
  • 1974 - 1978 B210
  • 1979 - 1982 B310
  • 1977 - 1988 200SX
  • 1989 - 1990 240SX
  • 1994 - 1998 240SX
  • 1975 - 1979 620 Pickup
  • 1980 - 1986 720 Pickup L20B,Z-series
  • 1986 - 1994 D21 Pickup
  • 1995 Pickup
  • 1987 - 1996 Pathfinder
  • 1974 - 1977 710
  • 1974 - 1976 Datsun 610
  • 1977 - 1981 810 L24E, LD28
  • 1970 - 1978 240Z, 260Z, 280Z
  • 1979 - 1983 280ZX
  • 1984 - 1989 300ZX VG30
  • 1982 - 1984 Maxima
  • 1978 - 1981 510
  • 1987 - 1988 Van
Mechanical Clutch (RHD)
See main articles Release Lever and Clutch
Hydraulic Clutch (LHD)
See Hydraulic clutch
Bearing Sleeve
Datsun 1200 release bearing sleeve/carriers
  • 30501-H1000 SLEEVE-BEARING CLUTCH RELEASE B110, early B120
  • 30501-H1000 SLEEVE-CLUTCH RELEASE B120 LB 7510-
  • 30501-H5000 SLEEVE-CLUTCH RELEASE B120 SB 7510-, B210 F4W56A
For A-series engines, there are two lengths. One is 4.5 mm longer.
Discussion: Clutch Problems
When swapping transmissions and engines, you should get them as a complete set:
  • Engine plate
  • Transmission
  • Release lever
  • Release bearing carrier
If you don't use a matching set, and after swapping transmissions you find the clutch doesn't engage correctly you may need to use the shorter Sleeve, or make your own longer sleeve.
Datsun Sleeve ID:
Differences
What determines whether you need to use the short or long bearing carrier?
  • Flywheel? Weight differs, but isn't the face depth the same A12/A14/A15? All B110 uses same flywheel, yet the GX-5 uses a different release bearing carrier sleeve. Likewise, all B120 utes use the same flywheel, yet SB uses one carrier and LB the other.
  • Transmission front case depth?
  • Clutch fork (release arm)? All 56-series B110/B210/B310 are the same. 60-series differs.
  • Engine plate (or lack thereof)? 30411 Rear Engine Plate
B110 uses no engine plate, only a dust cover as on the right:
Left: 5mm thick engine plate, used by B210 and later B120 (Datsun 1200 truck)
  • 30501-H1000 SLEEAVE-BEARING CLUTCH RELEASE B110
  • 30501-H1000 SLEEVE-CLUTCH RELEASE B120 SB
  • 30501-H5000 SLEEVE-CLUTCH RELEASE B120 LB
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B210 JDM A12
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B210 -0874 USA
  • 30501-H1000 SLEEVE-BEARING CLUTCH RELEASE B210 0974-0177 USA
  • 30501-H7000 SLEEVE-BEARING CLUTCH RELEASE B210 7607- JDM A14 F4W60L
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B210 -7606 JDM A14 F4W60L
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B210 0278- USA
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B310 56-series
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B310 60-series
  • 30501-H8560 SLEEVE-BEARING CLUTCH RELEASE B310 A12/A13 5-speed 60 series JDM
  • 30501-H5000 SLEEVE-CLUTCH RELEASE F4W56A
  • 30501-H7500 SLEEVE-CLUTCH RELEASE FS5W60A, F4W60L
  • 30501-H8560 SLEEVE-CLUTCH RELEASE JDM B310 A12 FS5W60(L?), A13 FS5W60A
63-Series Transmission
  • 30501-K0500 A14 FS5W63A JDM
    • Z31 VG30T.MT.M5 from 0986
