Release Bearing
Revision as of 04:08, 28 April 2011; view current revision
The clutch Release Bearing is often called the throwout bearing and is operated by the clutch Release Lever.
release bearing, throwout bearing
  • Bore = 1.5748
  • Outer Diameter = 2.8898
  • Width = 0.752
Bearing and spring are same: B110, B120, B210, B310 regardless of engine or transmission type. RHD and LHD are the same.
  • 30502-21000 BEARING-CLUTCH RELEASE
    • SKF N2106,N3048 $32
    • BCA/National 01576 $21.89
    • Timken DNB01576C $22
The bearing was originally designed for the Datsun 510 model series (part code 210), so fits many Datsuns, basically most RWD model with A-series, L-series, Z-series, KA-series or VG-series engines.
  • 1971 - 1973 Datsun 1200
  • 1974 - 1978 B210
  • 1979 - 1982 B310
  • 1977 - 1988 200SX
  • 1989 - 1990 240SX
  • 1994 - 1998 240SX
  • 1975 - 1979 620 Pickup
  • 1980 - 1986 720 Pickup L20B,Z-series
  • 1986 - 1994 D21 Pickup
  • 1995 Pickup
  • 1987 - 1996 Pathfinder
  • 1974 - 1977 710
  • 1974 - 1976 Datsun 610
  • 1977 - 1981 810 L24E, LD28
  • 1970 - 1978 240Z, 260Z, 280Z
  • 1979 - 1983 280ZX
  • 1984 - 1989 300ZX VG30
  • 1982 - 1984 Maxima
  • 1978 - 1981 510
  • 1987 - 1988 Van
Mechanical Clutch (RHD)
See main articles Release Lever and Clutch
Hydraulic Clutch (LHD)
See Hydraulic clutch
Bearing Sleeve
Datsun 1200 release bearing sleeve/carriers
  • 30501-H1000 SLEEVE-BEARING CLUTCH RELEASE B110, early B120
  • 30501-H1000 SLEEVE-CLUTCH RELEASE B120 LB 7510-
  • 30501-H5000 SLEEVE-CLUTCH RELEASE B120 SB 7510-, B210 F4W56A
For A-series engines, there are two lengths. One is 4.5 mm longer.
Discussion: Clutch Problems
When swapping transmissions and engines, you should get them as a complete set:
  • Engine plate
  • Transmission
  • Release lever
  • Release bearing carrier
If you don't use a matching set, and after swapping transmissions you find the clutch doesn't engage correctly you may need to use the shorter Sleeve, or make your own longer sleeve.
Datsun Sleeve ID:
Differences
What determines whether you need to use the short or long bearing carrier? It seems the diff and propeller shaft would have no effect on this. The dimension difference is beween the engine and transmission case and what's in between:
  • Engine block rear face/crankshaft spec?
  • Transmission front case depth?
  • Flywheel? Weight differs, but isn't the face depth the same A12/A14/A15? All B110 uses same flywheel, yet the GX-5 uses a different release bearing carrier sleeve. Likewise, all B120 utes use the same flywheel, yet SB uses one carrier and LB the other.
  • Clutch fork (release arm)? All 56-series B110/B210/B310 are the same. 60-series differs.
  • Engine plate (or lack thereof)? 30411 Rear Engine Plate
B110 uses no engine plate, only a dust cover as on the right:
Left: 5mm thick engine plate, used by B210 and later B120 (Datsun 1200 truck)
B110: is the transmission front case dimension different? B110 no plate, 3/4spd - carrier H1000 B110 plate, 5-speed - carrier H5000
B120: Transmission front case differs, but how? B120 no plate, Long Body - carrier H1000 B120 plate, Short Body - carrier H5000
B210 plate, 60-series - carrier H1000 B210 plate, 56-series - carrier H5000
  • 30501-H1000 SLEEAVE-BEARING CLUTCH RELEASE B110
  • 30501-H1000 SLEEVE-CLUTCH RELEASE B120 SB
  • 30501-H5000 SLEEVE-CLUTCH RELEASE B120 LB
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B210 JDM A12
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B210 -0874 USA
  • 30501-H1000 SLEEVE-BEARING CLUTCH RELEASE B210 0974-0177 USA
  • 30501-H7000 SLEEVE-BEARING CLUTCH RELEASE B210 7607- JDM A14 F4W60L
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B210 -7606 JDM A14 F4W60L
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B210 0278- USA
  • 30501-H5000 SLEEVE-BEARING CLUTCH RELEASE B310 56-series
  • 30501-H7500 SLEEVE-BEARING CLUTCH RELEASE B310 60-series
  • 30501-H8560 SLEEVE-BEARING CLUTCH RELEASE B310 A12/A13 5-speed 60 series JDM
  • 30501-H5000 SLEEVE-CLUTCH RELEASE F4W56A
  • 30501-H7500 SLEEVE-CLUTCH RELEASE FS5W60A, F4W60L
  • 30501-H8560 SLEEVE-CLUTCH RELEASE JDM B310 A12 FS5W60(L?), A13 FS5W60A
63-Series Transmission
  • 30501-K0500 A14 FS5W63A JDM
    • Z31 VG30T.MT.M5 from 0986
