Wiring Diagram
Revision as of 23:50, 23 June 2011; view current revision
WARNING: Wire colors can vary by year, model and country. Please double-check the wiring in your Datsun 1200 before connecting parts according to this article. You don't want to burn something up! Use a voltmeter or test light to confirm the circuit behavior.
B110
Datsun 1200 except USA & Canada
High-Res 1971 USA Intro Diagram. JDM and Australia is probably the same except for the headlight switch.
UK 1200 nearly the same as USA, same wire colors too
for manual transmission
1971 USA, same as or very close to JDM
1971 USA is same or very similar to non-USA.
1972
Minor changes from 1971, mostly additions.
Two-part high res 1519x1024
RED: Changes from 1971
  • Automatic Choke and relay
  • dash lamp labeled "IGN" instead of "CHG"
  • ACC circuit added to Ignition Switch (radio and heat glass)
  • Heat Glass added to diagram
  • Heater and switch wired differently
GREEN: New for 1972 emission control for manual transmission vehicles
  • cutting valve solenoid (for TCVAS)
BLUE: Automatic Transmission models only
  • Kick Down switch on gas pedel & solenoid on transmission
  • Inhibit Switch (Park/Nuetral switch on transmission)
1973
USA 1973 Manual Transmission
CAUTION: different from 1972-1972, and from non-USA
New for 1973
  • anti-diesel solenoid
  • nuetral detect switch
  • Heater illumination
  • seat & retractor switch (?)
  • Ballast resistor deleted (?)
  • Speed switch & throttle opener solenoid (?)
Clarified
  • "Indicator Lamp" now labled "Indicator Lamp (A/T)"
  • "Heat Glass" hnow "rear defroster"(Canada only) switch & defroster and shows 10A fuse
Changes from 1972
  • Door switch changed to two-pole with color change from BR to B
    • warning buzzer colors from R to BR
    • warning switch from R to L
  • Wire colors rationalized
    • TCVAS fuse wire color from BW to L
    • Left t/s color body/rear harness (makes it consistent with front harness) from 2nd GB to GR
    • High-beam switch. headlight feed changed to R (from RY) to match headlight switch. High beam out changed to RY from RW to match dash lamp wire color instead of matching headlamp wire color.
B120
Australia
1978 Australia 1200 ute
3 parts each 656 x 1280
Total size 1968 x 1280
Other RHD
Differences between 1978 Australia and 1978 other RHD
Horn "Low" is optional in Australia
* standard for other RHD countries.
Transmission switches
* Australia: Spade connectors for Back-up lamp switch
* Other RHD has Round multi-connector to:
** Spade connectors for Top Gear switch
** Spade connectors for Back-up lamp switch
Other RHD has:
* T/O Cut Solenoid
* Vacuum Cut Solenoid
* Speedometer has speed switch and attached SW amplifier
* Heater is optional
* Dimmer dash illumination switch
** Has usual six-connector rectangular connector
** Has additional 1-spade wire for Twist Control
** Two-position: Normal and Dim (not continously variable)
LHD
Left-hand Drive 1978 B120 has these differences from RHD:
* Cigarette lighter is not illuminated
Otherwise may be identical as far as colors and wires, but presumably the length of many wires differ.
B122
Late-model Sunny Truck from October 1989
B210 Early RHD (Australia?):
