Also see:
Part Numbers Index Main articles for usage, photos, cross-reference Relay Fuse Box Horn Hazard Switch Cigarette Lighter Lighting System Wipers & Heated Glass
Lights, Glass, Hazards
1 25160-H1010 COMP-SWITCH LIGHTING WITH FOG SWI OP 1 25160-H4600 COMP-SWITCH LIGHTING 0172- 0 25160-H1010 1 B5160-B6800 COMP-SWITCH LIGHTING 0172- 25160-H4600 1 25160-H1001 COMP-SWITCH LIGHTING B5160-B6800 COMP-SWITCH LIGHTING 25160-H1001 2 25165-H1000 KNOB-LIGHTING SWITCH 2 25165-H4600 KNOB-LIGHTING SWITCH 0172- 0 25165-H1000 25165-T3000 KNOB-LIGHTING SWITCH 25165-H4600 3 25199-H1000 SPRING-SWITCH KNOB 4 25260-H1001 COMP-SWITCH WIPER 4 25260-H4600 COMP-SWITCH WIPER 0172- 0 25260-H1001 5 25260-H7000 COMP-SWITCH WIPER 0772- 0 25260-H4600 5 25260-H7001 COMP-SWITCH WIPER 0772- 2 25260-H7000 6 25265-H1000 KNOB-WIPER SWITCH DX 6 25265-H4600 KNOB-WIPER SWITCH 0172- 0 25265-H1000 7 25265-H7000 KNOB-WIPER SWITCH 0772- 0 25265-H4600 7 25265-H7001 KNOB-WIPER SWITCH 0772- 2 25265-H7000 25265-H5200 KNOB-WIPER SWITCH 25265-H7001 8 25199-H1000 SPRING 9 25170-H2510 ASSY-LAMP,ILLUMINATION AUTOMATIC 0772- 0 10 08964-10510 NUT-SPRING 0772- 11 08540-51612 SCREW 0772- 12 25330-H1000 COMP-CIGALETTE LIGHTER DELUXE(OP STD) 12 25330-H1001 COMP-CIGALETTE LIGHTER DELUXE(OP STD) 1072- 2 25330-H1000 B5331-H5001 COMP-CIGALETTE LIGHTER DELUXE(OP STD) 25330-H1001 13 B5330-H1001 ELEMENT-CIGAR LIGHTER DELUXE(OP STD) 14 25290-H1900 COMP-SWITCH HAZARD 14 25290-H4600 COMP-SWITCH HAZARD 0172- 0 25290-H1900 25290-H4601 COMP-SWITCH HAZARD 25290-H4600 15 08513-30812 SCREW FIXING HAZARD SWITCH 3 16 08915-13310 WASHER-SPRING 3 43 25230-H2200 SWITCH-HEAT GLASS OP. 1270- 44 08510-51212 SCREW 2 OP. 1270-
Horn, Fuse & Electrical Unit
17 25540-H1100 COMP-SWITCH TURN SIGNAL & DIMMER WITH OP 17 25540-H1006 COMP-SWITCH TURN SIGNAL & DIMMER -1272 2 17 25540-H1007 COMP-SWITCH TURN SIGNAL & DIMMER 0173- 2 25540-H1006 18 25410-H1000 BLOCK-FUSE 25410-B5102 BLOCK-FUSE 25410-H1000 19 B5415-H1000 COVER-FUSE BLOCK OP 20 08941-11000 FUSE (10A) 3 21 08941-11500 FUSE (15A) 5 22 08510-51212 SCREW 2 23 08915-13510 WASHER-SPRING 2 25240-G150A SWITCH-OIL PRESSURE ENGINE 25240-89910 24 25240-89910 SWITCH-OIL PRESSURE ENGINE 25 25360-89900 SWITCH-DOOR DELUXE(OP STD) 25 25360-89915 SWITCH-DOOR 0172- 0 25360-89900 26 25320-H1000 SWITCH-STOP LAMP 27 25520-89911 UNIT HAZARD FLASHER 2 25520-89990 25520-89997 UNIT HAZARD FLASHER 2 27 25520-89990 UNIT HAZARD FLASHER 2 2 25520-89911 28 08510-51012 SCREW-TAPPING 2 29 08915-13510 WASHER-SPRING 2 B5520-89993 UNIT-FLASHER 12V 50W 25520-89901 30 25520-89901 UNIT-FLASHER 12V 50W 31 08510-51012 SCREW-TAPPING 2 32 08915-13510 WASHER-SPRING 2 33 26310-H1000 HORN-HIGH 33 26310-H1800 HORN-HIGH COUPE 34 26330-H1000 HORN-LOW SEDAN 25620-G2501 HORN-LOW COUPE 26330-H1800 34 26330-H1800 HORN-LOW COUPE 35 08110-81410 BOLT-HEX M8 4 36 08915-13810 WASHER-SPRING 4 37 26320-14800 RELAY-HORN 38 08310-51062 SCREW-MACHINE WITH LOCK WASHER 39 26320-89905 ASSY-RELAY,PASSING OP 0471- 40 08513-51012 SCREW 2 OP 0471- 41 25390-20300 SWITCH-KICK DOWN AUTOMATIC 42 36011-89901 SWITCH-HAND BRAKE 42 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- 36011-89901 45 22110-N0901 ASSY-SWITCH, THERMOSTAT MANUAL 0671- 46 08510-51212 SCREW MANUAL 0671- 25235-P0101 ASSY-RELAY,HEATER,AUTO CHOKE 25235-P0100 47 25235-P0100 ASSY-RELAY,HEATER,AUTO CHOKE 0671- 48 08513-61212 SCREW 2 0671-
Buzzer & Warning
49 26350-89905 BUZZER 0172- 50 08513-51012 SCREW 4 0172- 51 48780-H1900 BRACKET-BUZZER 0172- 52 25230-89918 ASSY-RELAY AUTOMATIC 0172- 53 25231-H4600 BRACKET-RELAY AUTOMATIC 0172- 54 08513-51012 SCREW 2 AUTOMATIC 0172- 55 26495-H4600 LAMP-SEAT BELT WARNING 0172- 56 08961-44810 NUT-PUSH 2 0172- 57 25310-H4600 SWITCH-SEATING OP 0172-
