Turn Signals
Revision as of 18:17, 14 May 2012; view current revision
Category: Lighting System
Turn signal or flashers, blinkers, indicators, winkers. All 1200s have them. Optional was a switch with built-in passing button at the end of the stalk, which flashes the high beams.
Also See
These components comprise the T/S system:
  • T/S switch (in steering column)
  • Light Switch (in dash, controls head/running/T/S)
  • Wiring & Fuse
  • Lamps (lens & socket & bulbs)
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
Switch Removal and Installation
  1. Remove Steering Wheel
  2. Remove Steering Column cover (clamshell)
  3. Unplug wiring connectors down along steering column
  4. Remove position screw
  5. Remove the two clamping screws
  6. Pull straight off column
Troubleshooting
See Turn Signal Testing
Switch Assembly
  • 25540-H1007 SWITCH COMP-turn signal & dimmer STD, B120 -7803 $155.78 USD
    • superceded 25540-H1006
  • 25540-H1100 SWITCH COMP-turn signal & dimmer
    passing switch type
    • OPTION DX, GL, GX
    • Optional on B120 -7803
    • Standard on B120 7804-
Hazard & Parking Light Switch
  • 25290-H4600 COMP-SWITCH HAZARD 0172-
    • replaced 25290-H1900 COMP-SWITCH HAZARD
    • 08513-30812 SCREW FIXING HAZARD SWITCH (3)
    • 08915-13310 WASHER-SPRING (3)
JDM
  • 25290-H1001 SWITCH ASSY-hazard & parking B110 [also used by B120 -7803]
    3-button Hazard & Parking Switch
    • 85-13308-12 SCREW (3)
    • 89-15133-1 WASHER-lock (3)
  • 25880-H2500 SWITCH COMP-hazard & parking PB110
B120 Pickup Early
  • 25290-H1001 SWITCH ASSY-HAZARD & PARKING -7803 [also used by sedan/coupe/van]
    • 08513-30812 Screw, fixing
Facelift (brown?)
  • 25290-G1060 SWITCH ASSY-HAZARD & PARKING 7804-8608
  • 25290-G1260 SWITCH ASSY-HAZARD & PARKING 8608-8910
Late Model (gray)
  • 25290-95W00 SWITCH ASSY-HAZARD & PARKING 8910-
  • Single Hazard button (no parking light buttons, as in earlier JDM switches)
Light Switch
  • 25160-H1101 SWITCH COMP-lighting B110 (also B120)
  • 25160-H1110 SWITCH COMP-lighting, with fog lamp switch (op.)
  • 25160-H2510 SWITCH COMP-lighting, w/o fog (op.)
  • 25160-H2511 SWITCH COMP-lighting, with fog (op.)
  • 25165-H1000 KNOB ASSY-lighting
  • 25165-E7500 KNOB ASSY-lighting, with illumination, w/o fog (op.)
  • 25170-H2510 LAMP ASSY-illumination (op.)
Custom
Also here's a custom update: Add a Bluebird multi-switch. Bolts to the 1200 column:
  • T/S switch
  • Light switch
  • Wiper switch
