Also see:
Part Numbers Index Main article for usage, photos, cross-reference Rear Suspension Leaf Springs Shocks
REAR SUSPENSION 1 55020-H1000 ASS'Y-SPRING, rear 2 Sedan, Coupe 2 55020-H1400 ASS'Y-SPRING, rear 2 Van 55020-G1000 SPRING-ASS'Y, rear 2 Truck 3 55203-H1001 MOUNTING-rear suspension, front 2 Sedan, Coupe 55203-H2500 MOUNTING-rear suspension, front 2 Sedan, Coupe (from '73-2) ^ 55203-H1001 4 55219-H1001 PLATE-rear suspension, front upper/inner 2 Sedan, Coupe 55219-H2500 PLATE-rear suspension, front upper/inner 2 Sedan, Coupe (from '73-2) ^ 55219-H1001 5 55044-H1001 BUSHING-rear suspension, front, upper 8 Sedan, Coupe 6 55045-H1000 BUSHING-rear suspension, front 4 Sedan, Coupe 7 08915-23810 WASHER-lock (fixing rear susp., front) 6 Sedan, Coupe 8 89-15238-1 NUT (fixing rear susp., front) 6 Sedan, Coupe -1971 08915-60810 NUT (fixing rear susp., front) 6 Sedan, Coupe 1972- 9 55210-H1400 ASSY-PIN, rear suspension, front 2 Van, Truck 55210-H6600 PIN-ASS'Y, rear suspension, front 2 Van (from '73-2) ^ 55210-H1400 10 55045-H1400 BUSHING-rear suspension, front 4 Van, Truck 11 08911-64010 NUT 2 Van, Truck 12 08915-24010 WASHER-lock 2 Van, Truck 13 81-90812-1 BOLT 4 Van [early] 08190-82010 BOLT 4 Van, Truck 14 08915-23810 WASHER-lock 4 VAN 15 55220-H1000 ASS'Y-shackle, rear suspension, rear 2 16 55221-H1000 PLATE-shackle, rear suspension, outer 2 17 55046-H1000 BUSHING-shackle, rear suspension, upper 4 18 55047-H1000 BUSHING-shackle, rear suspension, lower 4 19 08915-23810 WASHER-lock (fixing rear suspension front) 4 20 08911-60810 NUT (fixing rear suspension front) 4 21 55266-G1000 SEAT-rear suspension, lower (L.H.) Truck 55262-H1001 SEAT-rear suspension, lower 2 Sedan 55262-H2801 SEAT-rear suspension, lower 2 Sedan (from '73-5) <x> 55262-H1001 55262-H1401 SEAT-rear suspension, lower (R.H.) Van 55262-H1402 SEAT-rear suspension, lower (R.H.) Van (from '73-6) <x> 55262-H1401 22 55266-G1000 SEAT-rear suspension, lower (L.H.) Truck 55266-H1401 SEAT-rear suspension, lower (L.H.) Van 55266-H1402 SEAT-rear suspension, lower (L.H.) Van (from '73-6) <x> 55266-H1401 55262-H1801 SEAT-rear suspension, lower (R.H.) Coupe 55262-H1802 SEAT-rear suspension, lower (R.H.) Coupe (from '73-5) <x> 55262-H1801 55266-H1801 SEAT-rear suspension, lower (L.H.) Coupe 55266-H1802 SEAT-rear suspension, lower (L.H.) Coupe (from '73-5) <x> 55266-H1801 23 55247-G1000 CLIP-rear spring 4 Truck 55247-H1001 CLIP-rear spring 4 Sedan, Coupe 55247-H1002 CLIP-rear spring 4 Sedan, Coupe (from '73-5) <x> 55247-H1001 24 55247-H1401 CLIP-rear spring 4 Van 55247-H1402 CLIP-rear spring 4 Van (from '73-6) <x> 55247-H1401 25 55248-H1000 PLATE-clip, rear spring 2 Sedan 55248-H1000 PLATE-clip, rear spring 2 Sedan (from '73-5) <x> 55248-H1000 27 55240-H2500 BUMPER-ASS'Y, rear axle 2 Truck 55240-H1400 ASS'Y-BUMPER, rear axle 2 Van, Coupe 55240-H1800 ASS'Y-BUMPER, rear axle 2 Van, Coupe (from '73-5) <x> 55240-H1400 28 08911-64010 NUT 8 29 08915-14010 WASHER-lock 8 30 55350-H1000 TORQUE-arrester, rear suspension Sedan, Coupe 31 08915-23610 WASHER-lock (fixing torque arrester) 2 Sedan, Coupe 32 81-10616-1 BOLT (fixing torque arrester) 2 Sedan, Coupe 08910-61601 BOLT (fixing torque arrester) 2 Sedan, Coupe 08910-61625 BOLT-fix head with washer 2 Sedan, Coupe <> 08910-61601
1 55020-H1000 ASSY-LEAF SPRING REAR (2) 2 SEDAN COUPE 2 55203-H1001 MOUNTING-FRONT LEAF SPRING (2) 2 SEDAN COUPE 2 55203-H2500 MOUNTING-FRONT LEAF SPRING (2) 2 SEDAN COUPE 0273- 3 55219-H2500 PLATE-FRONT OUTER LEAF SPRING (2) 2 SEDAN COUPE 0273- 2 40323-18000 3 55219-H1001 PLATE-FRONT OUTER LEAF SPRING (2) 2 SEDAN COUPE 4 55044-H5001 BUSH-FRONT UPPER LEAF SPRING (8) 8 SEDAN COUPE 2 55044-H1001 4 55044-H1001 BUSH-FRONT UPPER LEAF SPRING (8) 8 SEDAN COUPE 5 08915-23810 WASHER-LOCK UPPER (4) 4 SEDAN COUPE 6 08911-60810 NUT-HEX M8X1.25 UPPER (4) 4 SEDAN COUPE 7 08915-23810 WASHER-LOCK LOWER (2) 2 SEDAN COUPE 8 08911-60810 NUT-HEX M8X1.25 LOWER (2) 2 SEDAN COUPE 9 55220-H1000 ASSY-SHACKLE LEAF SPRING REAR (2) 2 9 55220-G1900 ASSY-SHACKLE LEAF SPRING REAR (2) 2 55220-H1000 10 55221-H1000 PLATE-SHACKLE LEAF SPRING OUTER (2) 2 11 55046-H1000 BUSH-SHACKLE REAR UPPER (4) 4 12 55047-H1000 BUSH-SHACKLE REAR LOWER (4) 4 13 08915-23810 WASHER-LOCK REAR (4) 4 14 08911-60810 NUT-HEX M10X1.25 REAR (4) 4 15 55262-H1001 SEAT-LEAF SPRING LOWER (2) 2 SEDAN 15 55262-H2801 SEAT-LEAF SPRING LOWER (2) 2 SEDAN 0673- 5 55262-H1001 16 55262-H1802 SEAT-LEAF SPRING LOWER RH (2) 2 COUPE 0673- 5 55262-H1801 16 55262-H1801 SEAT-LEAF SPRING LOWER RH COUPE -573 3 17 55266-H1802 SEAT-LEAF SPRING LOWER LH COUPE 0673- 5 55266-H1801 17 55266-H1801 SEAT-LEAF SPRING LOWER LH COUPE -573 3 18 55247-H1001 CLIP-REAR SPRING (4) 4 SEDAN COUPE -573 3 18 55247-H1002 CLIP-REAR SPRING (4) 4 SEDAN COUPE 0673- 5 55247-H1001 19 55248-H1000 PLATE-CLIP REAR SPRING (2) 2 SEDAN -573 3 19 55248-H1001 PLATE-CLIP REAR SPRING (2) 2 SEDAN 0673- 5 55248-H1000 20 55240-H1800 ASSY-BUMPER REAR AXLE (2) 2 COUPE 0673- 5 55240-H1400 20 55240-H1400 ASSY-BUMPER REAR AXLE (2) 2 COUPE -573 3 21 08911-64010 NUT-HEX M10X1.25 (8) 8 22 08915-14010 WASHER-SPRING LOCK (8) 8 23 55350-H1000 APRESTER-TORQUE REAR SPRING SEDAN COUPE 24 08915-23610 WASHER-SPRING LOCK (2) 2 SEDAN COUPE 25 01111-00022 BOLT-HEX M6X1.0 (2) 2 SEDAN COUPE 26 08911-10810 NUT-HEX M8X1.25 (2) 2 COUPE 27 08915-13810 WASHER-LOCK (2) 2 COUPE 28 56200-H1001 COMP-ABSORBER SHOCK REAR (2) 2 SEDAN 29 56113-09400 WASHER (2) 2 SEDAN 30 55240-H1001 BOUND BUMPER A (2) 2 SEDAN 31 56124-H1001 BOUND-BUMPER B (2) 2 SEDAN 32 56112-09400 BUSH (2) 2 SEDAN 33 56123-H1000 SEAT-BOUND BUMPER (2) 2 SEDAN 34 56218-H1000 BOLT-SHOCK ABSORBER LOWER MOUNTING (2) 2 SEDAN 35 08911-14210 NUT-HEX M12X1.25 (2) 2 SEDAN 36 08915-24210 WASHER-SPRING LOCK (2) 2 SEDAN 37 56210-H1825 KIT-ABSORBER SHOCK REAR (2) 2 COUPE 38 56125-18000 BUSH-RUBBER (4) 4 COUPE 39 08911-10810 NUT-HEX M8X1.25 (4) 4 COUPE 40 08911-30810 NUT-HEX (2) 2 COUPE 41 56124-18000 BUSH-RUBBER (4) 4 COUPE 42 56122-18000 WASHER'A' (2) 2 COUPE 43 56123-18000 WASHER'B' (2) 2 COUPE 44 08915-13810 WASHER-SPRING LOCK (2) 2 COUPE
