Fan belt
Revision as of 21:47, 21 July 2012; view current revision
Category: Cooling System
Datsun 1200 uses a tradition V-belt to drive the engine accessories. This is commonly called the "fan belt" because it drives the Water pump and Radiator fan.
Minor Maintenance
USA 1972 Owners manual (see page 35 for fan belt information):
Fan belt slackness: 10-15mm
To check the fan belt tension, loosen the Alternator adjusting link bolt and adjust the tension by moving the alternator.
Check the belt slack between the alternator and the fan pulley and adjust it.
Fan belt slackness: 0.394 to 0.591 in (10 to 15 mm)
V-belt
  • NISSAN: 11720-18002 BELT-FAN L=838 (838 mm length, 33.0 inches)
    V-belt, 29/64 inch by 33.5 inch length. About $6
  • V-belt (AC models) 45 inches ~$10
  • $5.99 Partsamerica.com Drive-Rite B70895
  • Gates 20777
  • Goodyear Gatorback 15335 11AVO840 0535 97 (7/16 x 33.0 inch)
  • Gates 9330 XL or Green Stripe Belt 1-3 (177S) (12mm x 848mm/33.4 inch)
  • 1971-1973 Datsun 1200
  • 1962-1967 AMC six w/manual steering
  • 1967-1969 Chevrolet w/o brake booster
  • 1999-2002 Daewoo 1.6 a/c belt
  • 1985-1988 Dodge Colt A/C
  • 1990-1993 Hyundai Excel A/C
  • 1982 Mazda 626 A/C w/o power steering
  • 1977 Mazda 8080 air pump
  • 1985-1988 Mitsubishi Mirage A/C
  • 1980-1985 Nissan 720 A/C [some]
  • 1982-1983 Nissan Maxima 2.8 power steering pump
  • 1985-1988 Plymouth Colt 1.5 A/C
  • 1976-1979 Renault
  • 1986 Camry 2.0
  • 1980 Toyota Pickup air pump
  • 1969-1975 Volvo 164 power steering pump
NOTE: B210 and B310 models are different. See Radiator for a comparison of various fans, pulleys and fan belts.
