Propeller Shaft
Revision as of 05:52, 13 February 2007; view current revision
Category: Propeller Shaft And Differential Carrier
Datsun 1200 used two types of Propeller Shaft:
If yours has snap rings (C-shaped circlips) holding the U-joints in, they are replaceable.
Automatic driveshaft/tailshaft differs from Manual Transmission.
B210 with H145 Differential and B110 use the same tailshaft.
B210 with H150 diff use same shaft as B310 (?)
B120 with H165 differential *may* be same as B310 shaft (?)
Longbed Trucks use a 2-piece tailshaft.
