Diff Widths
Revision as of 11:09, 18 January 2016; view current revision
Categories: Rear Axle And Rear Suspension | Propeller Shaft And Differential Carrier
Drum-to-drum Width of differential assembly:
  • Datsun B10: 1239 mm (48.8 in) H145 diff. Leaf mount plates 910mm centre to centre, 65mm wide
  • Datsun B110: 51.36 in (1305 mm) or 46.6" (1185 mm) axle flange-to-flange (less brakes)
  • Datsun B310: 53.5 in (1360 mm)
  • Datsun C20 Vanette: around 1400mm (105mm wider than a 1200)
  • Datsun 510: R160 diff
  • Datsun V510: 53 in
  • Datsun 320 50 in H190 diff
  • Datsun 521 53 in
  • Datsun 521 52.25"
  • Datsun 620 early: 52.875" (620 with front Kingpins, e.g. 1976)
  • Datsun 620 late: 54" (620 with front Spindles, e.g. 1978)
  • Datsun A10 wagon (leaf type) 49" between backing plates. Estimated 53" axle wheel flange to flange. 1190 cm overall drum to drum
  • Datsun SR310/SRL310 "1500" roadster H165 axle housing length 45.75"
  • Datsun SR311/SRL311 "1600" roadster H190 axle housing length 43.50"
  • Datsun S110 "200SX" H165: 54 in
  • Nissan S12 "200SX" H190: 57(?) in
Leaf pad centers
* PL521 1116 mm leafs 60mm wide
* PL620 1116 mm left 60mm wide
Axle tube flange width
* PL521 1177 mm
* PL620 1190 mm
Rear "Tread" @ offset
* PL521 1267 mm 4Jx14
* PL620 1280 mm 4Jx14
