Heater
Revision as of 02:31, 13 February 2013; view current revision
Categories: Heating And Ventilation Systems | Body Electrical System
Heater was optional in the Standard model for most countries. All USA models came with a heater (by law).
Coolant Flow to Heater
Heater Hose Dimension
OD: 18mm
Radiator hose inlet
OD: 27mm(flare 29mm)
Diameter at block end: 26mm
Length: 162mm
Heater hose inlet
OD: 16mm(Flare 17.5mm)
Operation
USA 1972 Owners manual (see pages 18-19 for details):
Comfort and Convenience
TIP: Pull heater level out to switch fan speeds.
Also see: Ventilation
Heater Inspection
Heater core:
  • Leaks (before removing, check for leaks in passenger area, under carpet, on firewall cardboard, etc)
  • Flow (ensure it is not plugged). You can test similar to radiator blocked test
  • Clean out debris in exterior of core
Hoses: Check for cracks, overly soft hoses, tight clamps
Flow valve: ensure it opens & closes easily through entire range. Also check linkage for easy and complete movement (before taking apart)
Air ducts: Ensure they are clean and connected properly
Electrical: Ensure fan spins at both High & Low speed
Coolant Thermostat: Test
Heater Cock
also see: photo gallery
Heater cock
  • X2160-30600, X2161-30600 ASSY-VALVE WATER CONTROL B110 USA $18 USD
  • 27017-B8520 COCK- ASSY-FRONT HEATER 7510- B120
B110 Coupe/Sedan 19457.jpg
  • 27017-H5000 B210
  • 27017-N5000 B210 w/Aircon
Compare to other similar units:
  • Datsun 240Z
Core
The heater core is like a small radiator. The heater fan removes heat and blow it into the passenger compartment.
Same part number 1970-1994 1200 sedan/ute/coupe JDM and USDM markets.
  • 27013-H1001 CORE ASSY-FRONT HEATER
B210 is 27013-H5000, so a different part.
Heater Hoses
The heater hoses are 1/2 inch inside diameter hose. However, the original Nissan hoses were thin wall. Standard 1/2 inch hose is thick wall and will work but has to be forced through the firewall grommets.
Also, the original Nissan thin-wall hoses had a braided cover like this:
Original long heater hose is braided. Compare to the rear heater hose, which has been replaced with a plain hose.
Outlet (long) heater hose
Outlet Connector (fits in between the two lower radiator hoses):
  • 27051-E0100 CLIP-WATER (2) [for radiator hoses]
  • 08723-12000 CLAMP-HOSE (1) [for heater hose]
Inlet connector fitting (back of cylinder head)
B110
  • 27021-H1000 HOSE-WATER [to outlet, front of engine] $7.50
    • 27078-B2000 CLIP (2) [Fixing hose to air cleaner bracket]
    • 08510-51012 SCREW-TAPPING (2)
    • 08915-43510 WASHER-PLAIN (2)
  • 27075-H1000 CONNECTOR-WATER OUTLET [lower radiator hose T-connector] $9.97
  • 27070-H1000 CONNECTOR-WATER INLET [rear of cylinder head] $4.13
  • 27020-G1900 27020-H1000 HOSE-WATER [from inlet to cock] $9.88
  • X2160-30503 HOSE-WATER [from cock to core] $11.13
  • B7017-B8500 X2161-30600 X2160-30600 ASSY-VALVE WATER CONTROL $18.17
  • 27363-18200 27363-18001 GROMMET-HEATER (2) $0.53
  • 08723-12000 CLAMP-HOSE (5) $2.40
  • 08723-13600 CLAMP-HOSE (2) $2.57 [fixing hose to cock]
Complete set is about $80: 21501-H1000,21506-H1101,B7017-B8500,27022-H1000,27020-G1900,27075-H1000,B7021-H1002,27363-18001,01555-00841,01555-00281,27070-H1000
B120
Late from Oct 1989
  • 92402-95W00 HOSE-FRONT HEATER, 5 [outlet (long) hose] NICHIRA B517
  • 27363-18200 GROMMET-RUBBER (2)
  • 01555-00221 CLAMP (4) 8910-
  • 92520-G1900 [for rear portion of hose]
    • 08120-61228 BOLT
  • 92520-G1900 CLAMP 9810- [for strut tower]
    • 08543-61012 SCREW
  • 27078-B2000 CLAMP [to air cleaner bracket]
    • 08110-61610 BOLT
    • 08911-10637 NUT
B120 early to Oct 1989
  • 92402-G1900 HOSE-FRONT HEATER, 5 NICHIRA B517
    • supercedes 92402-G1601, 92402-G1660, 92402-G1661
  • 08723-12000 CLAMP (3) -8910
  • 08723-12200 CLAMP (1) -8910
  • 01553-00013 CLAMP -8910 [clamp to hot air tube]
    • 08110-61610 BOLT
    Mid-year B120.
    • 1. Inlet hose 4
    • 2. Outlet hose 5
    • 3. Outlet hose connects to block water pipe
B120 Inlet Hose
  • 27020-H1000 HOSE FRONT HEATER, 4 [inlet (short) hose] 7510-8109
  • 27070-H1000 CONNECTOR-WATER RETURN 7510-8109
  • 27020-G1900 HOSE FRONT HEATER, 4 [inlet (short) hose] 8110-
    • 27070-H5000 CONNECTOR-WATER RETURN 8110-
  • 27022-H1000 HOSE-WATER
  • 27017-B8520 COCK ASSY-FRONT HEATER
By comparison, B210 parts are mostly different to Datsun 1200.
USA B210
REGULAR
X9525-30120 HOSE-WATER COCK TO CORE (NICHIRA)
27020-H5000 HOSE-WATER
27021-H6200 HOSE-WATER
HEAVY DUTY
27020-H6110 HOSE-WATER
27021-H6211 HOSE-WATER
14801-30503 HOSE-WATER,U TYPE
X9525-30082 HOSE-STRAIGHT
JDM Late B210
27020-H5000 HOSE-WATER HEATER 1
27021-H5000 HOSE-WATER HEATER 2
Removal
Heater was optional. If you wish to remove the heater, how is it done?
  1. Drain engine coolant
  2. Remove heater hose from the fitting behind the cylinder head and plug this fitting with a 1/2" rubber cap
  3. Remove heater hose from the lower radiator hose tee. Plug this fitting with a 1/2" rubber cap
  4. Remove heater from inside car, & plug the two holes in the firewall
You can either remove the fitting from the back of the head & put a plug in there, or get heater blank off rubbers & plug them both. You can get these from local Auto stores, it is 1/2" heater hose.
20668.jpg 00931-30610 PLUG-HEATER OUTLET HOLE
Heater hose plug for cylinder head (as fitted to no-heater models)
Or the simpler way: Run a new longer hose from front to back of engine.
The most elegant way: Remove both lower radiator hoses and the heater adapter, and replace with a single-piece lower radiator hose.
21794.jpg buy at Bprojects
Discussion: A-series heater removal
Heater Motor & Fan
See Heater Motor
See Heater Wiring
ヒーター ホース ヒーター モーター
