Steering Gearbox Swaps
Revision as of 05:58, 1 May 2016; view current revision
Category: Steering System
Only Datsun 1200 gearboxes fit. Nissan South Africa sells brand-new steering gearbox units for B140 which might fit. Datsun B310 uses a seperate column and gearbox with a flexible coupling. So it is not a direct replacement for vintage B110s.
Other Datsun Gear
Only Datsun 1200 gearboxes interchange with Datsun 1200s.
B110 mounts with one front bolt, two rear bolts. PB110, B210, B310, 510 mount with two front bolts, single rear bolt. Cherry uses Rack & Pinion, so it does not interchange
B310 48010-23100 OR 48010-23130 for A14/A15 (housing 48011-21400)
B310 48010-H8800 for A12A (housing 48011-H8800)
A10 48010-W5850 OR 48010-W5800 (housing 48011-U5200)
Factory Steering Boost
A page in the Japan-market Sunny Truck parts catalog appears to show a power assist system.
The page is titled "Group Index - Chassis". It uses a generic diagram to show which page of the catalog to look at.
It turns out the Sunny Truck did not have a power-assist option - those parts in the diagram don't have a page number but are marked '*' . It's just a generic picture used in all the catalogs. No factory 1200, not even the last 1990s version, used power steering.
Electric Power Steering
Late model Nissans and Toyodas use electric power steering.
Japan Kit
Discussion
Flaming River
Long the hotrodder's choice for custom steering systems, Flaming River sells electric steering gearboxes. This is a column-assist type, and can work with any steering gearbox that accepts a custom column.
Rack & Pinion
Rack & Pinion has been adapted to many Datsun 1200s.
See main article: Rack and Pinion Steering
