Sedan Grille
Revision as of 04:51, 23 December 2014; view current revision
Category: Body
Datsun 1200 Sedans were fitted with a stainless metal grille. 1200 Pickups from 1971-1977 use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Also see: Grille Overview, Badges
Original Grille
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
  • Japan market 1200s used "S" mark
  • Export market 1200s used "D" mark
Fitting
Click for full size pictures of the grille mount points:
grille mounts on Core Support
And the eyebrow trim mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to nearly all Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit it to a Coupe.
  1. Fit one L-shaped bracket to center top of front body. The top of bracket should be 1/8" from top of ledge.
  2. Fit two thin brackets to back of sedan grille
  3. Drill four holes in radiator support to correspond to the holes in the sheet bracket
    • Drill them 20mm to the side of the headlight rim screw holes
  4. Screw sheet loops to front of car
  5. Screw grille to sheet loop ends
Installing Round Headlights in Late Truck
Fit the headlight Rims (easiest to do with grille off car)
  1. coupe and late ute are missing the outer bracket:
  2. All core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
    96706-B0700 GROMMET for screw
Grille (1-3)
62302-H1003 ASS'Y-grille, radiator Sedan (exc. GX), Van, Truck -7803 $169.65 USD
62302-H2300 ASS'Y-grille, radiator Sedan GX
96706-B0700 GROMMET-SCREW (4 total) $1.00 USD
85-10410-4 SCREW (4 total)
Eyebrow Trim (head lamp Rim) (14-19)
62320-G1000 STD SUNNY TRUCK 1971-1973
62320-H1002 ASS'Y-RIM, head lamp (R.H) $39.17 USD
62321-H1002 ASS'Y-RIM, head lamp (L.H) $39.17 USD
85-30412-9 Screw: Stainless outside (1 per side)
96706-B0700 SCREW-grommet [square-hole wedgie](2 per side)
85-30412-9 SCREW (1 per side)
89-64104-4 NUT-spring (1 per side)
Surround Trim (20-25) Coupe, Sedan and Van
62322-H1001 SURROUND-radiator grille, upper $40.27 USD
* Attaches to hood/bonnet
85-40410-12 SCREW (6 needed)
62323-H1001 SURROUND-radiator grille, lower $27.13 USD
85-40410-9 SCREW (10 needed)
62324-H1051 SURROUND-radiator grille, side with rubber (R.H) $29.50 USD
4 screws, unlisted in catalog
62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side)
62325-H1051 SURROUND-radiator grille, side with rubber (L.H) $29.50 USD
Core Support Panels
See Body#Radiator Core Panels
1972 Minor Facelift
The 1972 JDM facelift introduced a new grille for sedans.
new grille
1972 sedan grille
62380-H3216 (62380-H3215?) inserts
grille
Retro-fitted to newer Sunny Truck:
Emblems
Late JDM intricate "S" grille emblem
62312-H3125 ornament
Customized
