S110 Brakes
Revision as of 02:53, 5 April 2014; view current revision
Category: Brake Modifications
Large 268 mm disc brake rotors from S110 or 280ZX can be adapted to B310 (Sunny/210) or A10 (Stanza/510) struts. Swap developed by Doug Morrisun.
This setup fits over most 13" wheels. Wheels with inside diameter less than 11.7" won't fit.
Rotors: 1980-1983 S110 (Gazelle/Silvia/200SX)
Calipers: 1983-1990 Nissan B11/B12 (Sentra/Sunny)
Adapter brackets: Morrisun Productions
Brake hoses:
As these rotors fit over the hubs, it adds about 13mm to the total track.
B310 hub diameter: ~154 mm
S110 rotor inside diameter: ~145 mm
Machining
S110 268 mm rotor & caliper requires some machining. But it gains ventilated rotors suitable for racing applications.
Stock hub is too large to fit inside the rotor hat
Machine outer diameter of hub down about 1/4"
Now it will slip on
Adapter
Buy or fabricate caliper adapter bracket.
Adapts the B12 Caliper to the B310 strut.
Parts
Rotors
The 268 mm rotors (NISSAN 43206-P6500/43206-R4800) are from the rear of:
1979-1981 S130 "Datsun 280ZX" rear
1979-1981 S110 "Datsun 200SX" rear
1981 910 "Datsun 810" rear (except gasoline wagon)
JAPAN
1979 910 "Datsun Bluebird" October to December
1981-1982 C31 "Nissan Laurel" upper models
Only $16 from Rockauto.com
* Centric 12142014
* Bendix PRT1181
* Beck/Arnley 0831750
* Raybestos 9225R
* Wagner BD97313
280ZX USA catalog (Turbo or Non-turbo. 2+2 or Coupe)
* 268 mm <-- this one
* 43206-P6500 ROTOR-DISC BRAKE,REAR 0778-0881 (1979-1981 Model year)
** superceded 43206-R4800 0778-0881
* 258 mm <-- NOT this one
* 43206-N9501 ROTOR-DISC BRAKE,REAR 0981- (1982-1983 Model year)
Specs
268 mm
* 268 mm Diameter (10.565 inch)
* Overall Height: 68.5 mm
* Thickness (nominal): 9.6 mm
* Thickness (minimum): 8.6 mm
* Hub Reg: 68 mm
* Bolt size: M12x1.25 (10.75 mm diameter)
* Bolt circle: 4 on 4.5" (114.3 mm)
* Weight: 5kg (11 pounds)
Lug Studs
Since the rotors fit over the hubs, they add about 1/4" to the mounting face of the wheels. So you *may* need slightly longer Wheel Studs, which are common from a wreckers or buy them new.
See 280ZX_Brake_Upgrade#Lug_Studs
