Datsun 1200 uses a tradition wet-sump oil pan, holding about 2.5 quarts of oil. It is a sheet metal part that plays no structural function. It is a front-sump design.
Oil Capacity
Datsun 1200 * Oil pan: 2-7/8 U.S. qts., 2-3/8 Imper. qts. (2.7 L) * Oil filter: 1-1/8 U.S. pints, 1 Imper. pint. (0.54 L)
Others: * A15 oil: 2.8 liter * A14 oil: 3.2 liter
The exact amount depends on the specfic oil filter used. Nissan filters come in several different sizes.
Drain Plug
Thread Size; M16.4-1.33; Under-Head Length: 12.00mm; Head Size: 21mm; Head Style: Flanged Hex
- 11128-69200 PLUG-DRAIN $3.57 USD
- Beck/Arnely 016-0058
- Dorman 90039
- 090039, 0900391, 1112869200, 11128U8000, 365235, 65235
- Datsun Roadster 1600 R16 engine
- Datsun Roadster 2000 U20 engine
- L-series/Z-series/CA18ET/SD25 engine
- 1986-1989 Nissan D21 KA24 engine
B110 USA RAW LIST
11110-H1001 ASSY-PAN OIL 1 A12 - NLA 11119-61000 SEAT-DRAIN PLUG 1 A12 - $1.67 11128-69200 PLUG-DRAIN 1 A12 - $3.57 11026-61000 GASKET-DRAIN PLUG 1 A12 - $1.60 11130-18002 SEAL-OIL OIL PAN FRONT 1 A12 - $1.29 11131-18002 SEAL-OIL OIL PAN REAR 1 A12 - NLA 11132-18001 GASKET-OIL PAN RH 1 A12 - $4.42 11133-18001 GASKET-OIL PAN LH 1 A12 - $4.08 08110-61410 BOLT M6 FIXING OIL PAN 1 12 A12 - $0.32 11025-18000 STUD-LOCATING OIL PAN GASKET 4 A12 - $0.58 08915-13610 WASHER-LOCK FIXING OIL PAN 1 16 A12 - $0.72 08911-1062A NUT M6 FIXING OIL PAN 4 A12 08911-10610 $0.10 08911-10610 NUT M6 FIXING OIL PAN 4 A12 - superceded 11140-H1002 GAUGE-OIL LEVEL 1 A12 - superceded 11140-H1003 GAUGE-OIL LEVEL (dipstick) 1 A12 0271- 2 11140-H1002 $7.82
Gasket
NISSAN gaskets are in 4 pieces: * 11130-18002 SEAL-OIL OIL PAN FRONT B110 - $1.29 * 11131-18002 SEAL-OIL OIL PAN REAR B110 - NLA * 11132-18001 GASKET-OIL PAN RH B110 - $4.42 replaced by 11132-H1000 * 11133-18001 GASKET-OIL PAN LH B110 - $4.08 replaced by 11133-H1000
Later they went to a SET: * 11132-H5025 GASKET SET-OIL PAN B210/B310/B120 A12,A12A,A13,A14,A15 1973 to 1994 includes: * 11130-18002 front * 11131-18002 rear * 11132-H5000 right * 11133-H1000 left <> 11133-18001 (change 0674)
Rockauto.com
DNJ PG604 Beck/Arnley 0340380 1971-1982 A-series engines A12/A12A/A14/A15 Victor/Reinz OS30055 * replaces 11121-H5025, 11121-H5220, 11132-H5025 Fel-Pro OS20074C-1![]()
The Datsun Factory Service Manual says to use sealer on both sides of the oil pan gasket, "especially on the front and rear portions of the pan". I believe the original was a cork gasket.
Oil pan side rails, cork or otherwise, needs no extra sealer. What it needs is:
- ensure the pan flange is flat. Many have been overtightened and won't seal correctly until straightened
- a dab of RTV sealer on the ends where the half-round gaskets meet the rail-sides. Do not put very much on.
- Do not overtighten. Factory torque is really low (they are only 6mm bolts). Tighten them to spec, then go round again and retighten.
Torque spec 0.4 to 0.6 kg-m 2.9 to 4.3 ft-lb 35 to 52 inch-lb
Early Blocks
1967-1973 - front distributor engine blocks
- Front Sump (B10 and B110 interchange)
Newer pans from Datsun B310 will fit the older A12. When the distributor was moved back for 1974 there was a change in the pan rail shape under the oil pump area which may prevent interchangeability between older oil pans and newer engines.
B10 pan - notice seam down the middle
1974 up Blocks
1974-up - mid-distributor engine blocks. All the A-series pans bolt to all A-series engines, but be sure to get the matching dipstick, dipstick tube and oil pump strainer to go with the pan.
Front sump A12, A12A, A14 * 11110-H5000 OIL PAN [same as JDM B210] Mid-sump (North American B210) * 11110-H7201 ASSY-PAN OIL ** Replaces 11110-H7201, 11110-H6200 A15 front sump pan with bulges, will retro fit into other A-series mid-dizzy engines. * 11110-H9700 OIL PAN [unique to A15]
The lack of clearances bulges on the "B" type pans prevents use on the A15, however the presence of bulges on the A15 pan does not interfere with its use on other rear dist engines.
A15 pan with stiffening ridges (for quieter operation)
Beware of using an early A-series pan on late engine.
Late pan -> all engine Early pan -> early engines only
North American B210 engines (A13 & A14) used a mid-sump (center sump) design.
Pickup Tube
A10 15050-18001 Oil Strainer 15050-18002 Oil Strainer (from '70-July)
B110/B210/B310/B120 15050-H1000 ASSY-STRAINER OIL A12/A13/A12A -8503 + A14 -8010 15010-H1001 STRAINER ASSY-OIL A14 8011- 15010-H9701 STRAINER ASSY-OIL A15 15010-H9702 STRAINER ASSY-OIL A12 8504- 15053-18000 GASKET-OIL STRAINER <> 15053-18010 08110-82062 BOLT (2) [M8 thread] 08915-13810 WASHER-LOCK (2)
FWD Models
- 1970-1974 Nissan E10 (Cherry)
- 1974-1978 Nissan F10 (Cherry, Datsun F10)
- 1978-1981 Datsun N10 (Cherry/Pulsar/310)
- 11110-M0100 JPN E10 PAN ASS'Y-oil (to '74-6)
- 11110-M0101 JPN E10 PAN ASS'Y-oil (from '74-7)
- 11110-M4965 F10 USA ASSY-PAN OIL 1176-
- superceded 11110-M3000 F10 USA -1076
- 11110-M6660 N10 USA PAN ASSY-OIL 0880-0781 A15S
- 11110-M6660 N10 USA PAN ASSY-OIL 0881-0780 A14S
- superseded 11110-M7000 N10 USA 0878-0780 A14S
オイル パン
Alloy Pans
Modified pan for turbo (not oil return fitting)
Nissan Competition Parts
From 1984 Nissan Competition Catalog
- 99996-H1050 B210 COMPETITION OIL PAN Completely baffled with special one-way pick-up tube designed to keep competition Oil pump primed
- 99996-H1052 1200/210 COMPETITION OIL PAN Specifications same as 99996-H1050
- 99996-H1135 SPECIAL OIL PAN GASKET Seals better than the stock gasket and can be reused when properly installed
- 11128-H2375 ADAPTER/OIL TEMP SENDING UNIT Will adapt a Stewart/ Warner manual oil temperature sending unit to any stock oil pan
Steel pan 99996-H1052 Front Sump
