Interior
Revision as of 22:03, 16 September 2015; view current revision
Category: Body
Datsun 1200 standard interior was elk-pattern black vinyl. Blue, Yellow, Ivory and Brown were also available in some markets, as well as fabric patterns.
Interior Trim Colors
Also see: Colors
Black was the original interior trim color. Regardless of exterior/interior color, blue vinyl floor mats were standard.
In Japan, black interior was most common.
STD: Black
DX: Black, gray or green
GL
G seat cloth (GL models)
D Black Vinyl (DX models)
K Yellow Vinyl (DX with green exterior)
820 Red (interior: Gray)
645 Blue (interior: Gray)
1973 USA
Blue interior
Yellow optional with 940 Yellow Green exterior
After Jan 1973, black became available?
Australia
Locally assembled sedans often came with brown, red, or white interiors.
Truck
Black was exclusively used for Ute 1971-1978
Brown was exclusively used 1978-1989
Gray was exclusively used 1989-1994, along with black vinyl floor mats
Sunvisors
See main article: Visors
Door Trim
Door
80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
Window Trim
Front window - 2-dr sedan
* 80260-H1000 Handle-vent R $19.67
* 80261-H1000 Handle-vent L $19.67
* 80760-H1000 Handle-regulatr $24.00
Rear window - 2-dr sedan
* 76828-H1200 Cover-hinge [rear window] $1.02 USD
* 76870-H1200 Handle-window RR $39.17 USD
* 76871-H1200 Handle-window RL $40.62 USD
** 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
* 76832-H1201 HINGE-SIDE WINDOW (4) NLA
Hinge Covers
Also consider B210 gray part:
* 76828-H5300, 76828-H5301 COVER-SIDE WINDOW HINGE B210 [GRAY]
Head Liner
The head lining covers and insulates the roof panel.
See main article: Upholstery#Headliner
Kick Panel
Kick panel is the front side panel, in front of door, under dash.
See main article: Kick Panel
Package Tray
See Package Tray for under-dash compartment
Coin trays
The seat riser trim is the little plastic pockets next to the door|s.
See main article: Seat Riser Trim
Below-door Trim
  • 74921-H1100 COVER-FLOOR SIDE FRONT RH
  • 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211
  • 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20
  • 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13
  • 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20
  • 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13
  • 74922-H1100 COVER-FLOOR SIDE FRONT LH
  • 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211
Parcel Shelf
Parcel shelf is the area above the rear seat, under that rear window.
See main article: Parcel Shelf
Also See
* Carpet
