Turn signal or flashers, blinkers, indicators, winkers. All 1200s have them. Optional was a switch with built-in passing button at the end of the stalk, which flashes the high beams.
Also See
These components comprise the T/S system:
- T/S switch (in steering column)
- Hazard switch (on column cover)
- Light Switch (in dash)
- Wiring & Fuse
- Lamps (lens & socket & bulbs) front, dash, rear
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
Switch Removal and Installation
- Remove Steering Wheel
- Remove Steering Column cover (clamshell)
- Unplug wiring connectors down along steering column
- Remove position screw
- Loosen the two clamping screws
- Pull straight off column
Flasher Location
non-USA
The flasher can is bolted to the right side of the steering column brace.
NILES Hazards & Turn Signal flasher unit bolts to right side of column brace
USA 1200s have two flashers.
NILES Hazard flasher unit bolts to right side of column brace
NILES Turn Signal flasher unit bolts to left side of column brace
Troubleshooting
Japan Flasher
Japan-market 1200s used a single flasher unit to operate both the Turn Signals or the Hazards (depending on position of the Hazard switch).
1200 including truck 25520-89974 UNIT-flasher, hazard & turn signal * supercedes 25520-89962
B210 1973-1975 25520-89974 UNIT-flasher, hazard & turn signal
Late B210 used seperate flashers for Turn Signal & Hazards.
B210 1976-1977 25520-89995 UNIT ASSY-TURN SIGNAL FLASHER 25520-89997 UNIT ASSY-HAZARD FLASHER [SAME AS USA]
USA Flasher Units
T/S flasher unit and Hazards flasher unit look similar (both are two-prong flashers), but are different specification. The load varies: Hazard flasher activates all lights at once, while T/S flasher does one side at a time.
Terminals X: battery L: lamp
Candlepower: 32 [32CP]
Cycles per Minute: 80 to 90 C/M
In the orginal B110/B210/B310 fitting, the T/S flasher was a large 40mm diameter NILES unit, while Hazard used the smaller 32mm NILES unit.
Turn Signal Flasher
T/S Flasher B5520-89993 UNIT-FLASHER 12V 50W $14 USD NILES CF115 (23W x 2 + 3.4 w [49.4 watt]) * superceded 25520-89901 used by * Datsun B110 USA * Datsun 510 * Datsun 520/521 * Datsun Fairlady AUS
B210 USA spec is different: 25520-89976 or 25520-89966
B310 USA spec is different: 25520-89983 (clip on, not bolt-on).
Hazard Flasher
Hazard flasher 25520-89997 UNIT HAZARD FLASHER $24 USD * supercedes 25520-89990 (original B110 spec) * superceded 25520-89996 (original B310 spec) NILES F215AF (23W x 2 + 3.4 w [49.4 watt]) NIEHOFF 562 used by * Datsun B110 USA * Datsun B210 USA * Datsun B310 USA
Aftermarket Units may replace one or both part numbers.
NIEHOFF 562 (suitable for Hazards) is compatible with: * 25520-89976 * 25520-89978 * 25520-89983 * 25520-89996 * 25520-89997 * 25520-B8060 * 25520-E46000 * 38300-634-671 * 38300-671-671 * 38300-671-672 * 38300-692-671 * 38300-692-672 * 38350-634-003 * 38350-634-671 * 38350-671-003 * 38350-671-013 * 2113-66-470 * 6832-10-072 * MB031754 * MB031755 * MB031756 * 6832-10073 * 7861-22000 used by: 71-85 American Motors 80-87 Aston Martin 71-85 Chrysler 71-85 Dodge 71-85 Dodge Truck 67-82 Ford (English) 70-84 Honda 61-82 Jaguar 68-82 Lotus 61-81 MG 70-84 Mazda 67-80 Mercury 83-91 Mitsubishi 71-85 Nissan-Datsun 71-85 Plymouth 71-85 Plymouth Truck
Universal Flasher
Flasher for either T/S or Hazards. My Sunny Truck is using this common USA unit.
Aftermarket universal thermal flasher BUSS FLASHER 552/536 12V $3.19 @ O'Reilly 2-terminal 32CP MAX6 Taiwan flashes 2-3 Turn Signal 32CP lamps flashes 2-6 Hazard lamps clip on type [no bolt-on tab, so zip-tie it under the dash]
Electronic Flasher
An "electronic" flasher may be used to accomodate non-stock bulbs, but requires extra wiring.
By contrast, the original thermal flasher types only work with a specific number and wattage of bulbs.
TS/Beam Switch Assembly
- 25540-H1007 SWITCH COMP-turn signal & dimmer STD, B120 -7803 $155.78 USD
- superceded 25540-H1006
- 25540-H1100 SWITCH COMP-turn signal & dimmer
- OPTION DX, GL, GX
- Optional on B120 -7803
- Standard on B120 7804-
Hazard & Parking Light Switch
- 25290-H4600 COMP-SWITCH HAZARD 0172-
- replaced 25290-H1900 COMP-SWITCH HAZARD
- 08513-30812 SCREW FIXING HAZARD SWITCH (3)
- 08915-13310 WASHER-SPRING (3)
JDM
- 25290-H1001 SWITCH ASSY-hazard & parking B110 [also used by B120 -7803]
- 85-13308-12 SCREW (3)
- 89-15133-1 WASHER-lock (3)
B120 Pickup
Early
- 25290-H1001 SWITCH ASSY-HAZARD & PARKING -7803 [also used by sedan/coupe/van]
- 08513-30812 Screw, fixing
Facelift (brown?)
- 25290-G1060 SWITCH ASSY-HAZARD & PARKING 7804-8608
- 25290-G1260 SWITCH ASSY-HAZARD & PARKING 8608-8910
Late Model (gray)
- 25290-95W00 SWITCH ASSY-HAZARD & PARKING 8910-
- Single Hazard button (no parking light buttons, as in earlier JDM switches)
Light Switch
- 25160-H1101 SWITCH COMP-lighting B110 (also B120)
- 25160-H1110 SWITCH COMP-lighting, with fog lamp switch (op.)
- 25160-H2510 SWITCH COMP-lighting, w/o fog (op.)
- 25160-H2511 SWITCH COMP-lighting, with fog (op.)
- 25165-H1000 KNOB ASSY-lighting
- 25165-E7500 KNOB ASSY-lighting, with illumination, w/o fog (op.)
- 25170-H2510 LAMP ASSY-illumination (op.)
Custom
Also here's a custom update: Add a Bluebird multi-switch. Bolts to the 1200 column:
- T/S switch
- Light switch
- Wiper switch
