Towing
Revision as of 21:01, 21 April 2016; view current revision
Categories: General Information | Documentation
Yes, your Datsun may be towed safely by another vehicle, with a few considerations.
Operation
See the Owner's manual: Operating the Car.
Owners manual
USA page 17
EXPORT page 25
TOWING
If the car is being towed with the rear wheel on the ground, do not exceed 17 MPH (30 km/h). The selector lever should be in the "N" position. If the transmission is inoperative, it is advisable to two with the rear wheels raised off the ground, or with the propeller shaft removed.
Being towed by the rear wheels
post
However, these instructions were updated later. The 1980 owner's manual says:
TOWING
CAUTION
  • It is necessary to use proper towing equipment to avoid possible damage...See the Towing Procedure Manual at dealer side.
  • All applicable government laws regarding the towing operation must be obeyed.
  • Before towing, make sure that the transmission, axles, steering system and power train are in good order. If any unit is damaged, a dolly must be used.
  • If the transmission is inoperative, tow the car with the rear wheels off the ground, or with the propeller shaft removed.
  • When the car is towed with its front wheels on the ground, secure the steering wheel in a straight ahead position with the ignition key turned in the "OFF" position.
  • When towing an automatic transmission model, try to restrict towing speed below 30 km/h (20 MPH) and towing distance less than 30 km (20 miles).
  • With manual transmission model, try to restrict towing speed below 80km/h (50 MPH) and towing distance less then 80 km (50 miles).
  • If the speed or distance must necessarily be greater, remove the propeller shaft beforehand to prevent damage to the transmission
  • Release the parking brake and set the gearshift lever in the "Neutral" position before starting to tow the car.
Factory-suggested Tow Points
Front - place rope around tension rod bracket
full
Rear - place rope around spring shackle
full
Rope-towed
Towbar
Being towed by towbar
full
Trailering
Being towed on a trailer seems very popular too.
Flatbed/flattray towing
full
4815.jpg 5923.jpg 6167.jpg 8600.jpg 8601.jpg 9256.jpg 13720.jpg 14040.jpg 14355.jpg 15402.jpg 19580.jpg
Tie-down
full
B10
