Fuel Piping
Revision as of 03:26, 28 October 2019; view current revision
Category: Fuel System
Datsun 1200 used steel and rubber fuel lines. As usual for the time period, no fuel return line was used until the emission-controlled 1989 models.
Chassis fuel line comes from the Fuel Tank into the Engine Bay. A rubber hose will connect it to the Fuel Filter
8710_53755dc04cb5a.jpgPost 455280
From the filter, a rubber hose goes to the Fuel pump, then out to the #Fuel Rail
Fuel Rail
17523-H1002 JDM TUBE-fuel pump to carburetor 7011- <> 17522-H1002 < 17522-H1000 -7010
17523-H1900 USA 0671-0370 0
17523-H1902 USA 0470- <> 17523-H1901
17523-H2300 GX
  • Right side of rocker cover middle
  • Left side of rocker cover rear (non-GX) or front (GX)
  • Front of fuel tube bolts to thermostat housing via clamp-bracket
Datsun 1200 Fuel Rail bolts to the rocker cover and thermostat Housing.
15170.jpgAlbum 15170
1200 GX fuel rail
8355.jpgAlbum 8355
B210 Fuel Rail bolts to the cylinder head, allowing for easier rocker cover removal
datto1418.jpg 25859.jpgAlbum 25859
17522-H8401 TUBE ASSY-FUEL A14T
Late B120 Sunny Truck from Oct 1989 has dual fuel/return line
1346.jpgAlbum 1346
EFI Fuel Rail
A14E and A15E use a circular fuel rail with attached fuel regulator.
See Main Article: EGI#Fuel_Piping
See Fuel Piping Part Numbers
