Some newer Nissans are fitted with electronic speedometer, which uses a signal sender bolted to the gearbox (instead of the cable drive).
[edit]
Signal Sender
The A14/A15 60-series gearbox can take an electronic sender for electronic speedometer, you can unbolt the cable drive and bolt in sender from S13 or R31 71C gearbox.
Cable drive | electronic sender
[edit]
Adapter Sender
Discussion: POST Interesting blog from japan ,late R32gts-t FS5W71C behind an a-series...![]()
[edit]
Speedometer
Auto Meter sells various sizes and styles of electronic speedometers.
Some guys fit an entire S13 cluster into the dash. See Custom_Dash#Silvia
