Datsun 1200 uses a common wheel bolt-pattern: 4 bolt holes on 4-1/2 inch circle (aka 4-on-4.5). Nissan engineers measured this in inches. In metric, this is equivalent to a 4 x 114.3 PCD (Positive Coefficient of Distance)
Stock Datsun 1200 wheels are 12 inch diameter, 4J (4 inches wide). All models, even GX models, used the same wheels. Only the Datsun 1200 SSS used a special wheel.
Compatible Wheels
Anything that is 4-bolt on 4.5 inch circle fits (depending on tire size), although the offset on many front-wheel drive wheels is too much.
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13). Pefect for the front, but The may need a 1/4 inch spacer to clear the brake caliper brackets in the front
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Hyundai Excel
- Ford Laser (KA to KH)
- Rear-wheel-drive Mitsubishi
- Early SAAB (5.5 inch wide)
What WONT work:
- Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- Newer SAAB (900 Turbo)
Also same as Nissan Pintara. These are 14" wheels.
aka "Pursuit" style rims as they are similar to police car (plain) wheels.
R31 Skyline or Pintara steelies
Don't pay more than $15 per steel wheel
The 5.5 wide wheels should fit.
The stock 6" and 7" wide Sillouettes won't fit the B110 or early B210 disc-brake strut. If you run Stanza or 240K struts, then no worries.
Stock Wheel Comparison
wheels | B110 | 1977 US B210 A14 | 1980 NA B310 |
size | 4 J-12 | 4-1/2 J-13 | 4J-12 Canada w/A12A 4-1/2 J-13 5 J-13 (aluminum) |
offset | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
tire size | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
balance (place weight on inside of rim) | 10gr or less (0.35 oz) | 11gr or less | 10gr or less |
lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Lug Nuts
- B110: 3/4" lug nuts
- B210: 13/16" lug nuts
Wheel Offset
The stock wheel is 4 inches wide with 30 mm positive offset (mounting face is 30mm outboard of the wheel's center line).
wheel offset and backspace diagram
Front-wheel-drive cars use wheels with high positive offset. This is to say that the mounting surface is far outboard of the wheel's center line. Often they will fit the 1200 if wheel spacers are used to bring the mounting surface back toward the wheel's centerline.
Stock Offset:
model | Wheel type | Offset | wheel width | Tire width |
B110 | steel | 30 mm (1.18 in) | 4" wide wheel | 155 mm |
B210/B310 | steel | 30 mm (1.18 in) | 4.5" | 155 mm |
B210/B310 | aluminum | 25 mm (0.98 in) | 5" wide wheel | 175 mm |
- Using B210 wheels on B110 results in a 1/2" (12.7 mm) wider overall rear width (measured by outside tire sidewall -to - sidewall). NOTE: These still fit under unmodifed B110 rear fenders.
- Steel vs. Aluminum wheels will have overall width 10-15 mm wider (tires are 10mm wider, wheels are 25.4 wider, but offset on each side in 5mm less)
Scrub Radius
Largest Sizes to Fit 1200
17-inch diameter wheels easily fit the 1200. The key is: width and overall height.
Wheel Adapters
Wheel adapters can be used. These bolt to the hub, then you can fit other wheels.
Suppliers
Wreckers are your best bargain here ... lots of 13, 14, 15, 16 and 17" wheels, even some 12s. Lots of 12s avaiable in US junk yards.
- http://classicdatsun.com has Panasports
Manufacturers
- Konig makes a retro-style wheel with the proper offset for RWD application. Konig Rewind
Mail order
- tirerack.com
- Minilite Wheels - The real deal! alloy racing wheels 12x5 only $159 each in Silver, Black, White. Gold and Anthracite also available.
Also see: Wheel Weights
