Bulbs
Revision as of 11:45, 5 September 2018; view current revision
<-- Back to: Lighting System
5021.jpgAlbum 5021
1. Exterior single element, one bottom contact
Rear T/S (turn signal) -- See Tail Lights
* 23 watt Type 1073
  * North America can also use 27 watt Type 1156 e.g. Wagner 1156
  * Japan
* 21 watt (other countries)
5021.jpgAlbum 5021
REAR INDICATORS
<-- single bottom contact
2. Exterior dual element, two bottom contacts
Dual-filament bulb
* Front park & T/S -- See Front Combination Lamp
* Rear Tail & Stop -- See Tail Lights
23/8 watt Type 1034
  * Japan
  * North America (can also use 27/8W Type 1157)
12/5 watt
  * other countries
5021.jpgAlbum 5021
DUAL FILAMENT BULB
double bottom contacts -->
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
5021.jpgAlbum 5021
3. FUSE
<-- 10A
23313.jpgFuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5021.jpgAlbum 5021
4. FUSE
15A -->
23313.jpgFuse Box
d
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
* 26945-H4600 (not sure if this lamp only, or whole unit)
 Type 3175
 Wagner 12100
5023.jpgAlbum 5023
6. Dome Lamp
10 watt (room lamp) 26736-89902
* Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w
* Type SV8 Type 5168 10 watt
* SV7-8 Festoon base (pointy ends)/ LES / SV7
Some parts stores specify the larger unit (see above Type 3175) which is readily available, but the Room Lamp socket must be bent slightly to fit.
7. Instrument Panel Lamp
Twist-lock holder (7 used in round dash).
26260-89900 Wedge Socket (7 total) $3.28 USD each
These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base. Possibly also be called W5W base).
T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
24884.jpgAlbum 24884
* 26261-89902 1.7 watt bulb (ROUND GAUGE)
  2.7 watt Type 161 is often specified by aftermarket
JPN B110
* 26261-89900 BULB-12V, 3.4W SQUARE METER 7
* 26261-89902 BULB-12V, 1.7W ROUND METER 7
JPN B120
* 26261-89900 7510-7803 12V-3.4W 商B113 8
  3.4 watt Type 158
* 26261-89902 7804- 12V-2.7W 商B113 6
* 26711-89900 7804- 12V-1.7W 商B113 2
* 26711-89902 8910- 12V-2.7W 商B113 6
* 26711-89900 8910- 12V-1.7W 商B113 2
T10 glass with T5/W5W base
* Type 194 1.0 watt
* Type 161 2.7 watt
NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
8. Exterior Lamp
Side-marker lamp
* 8 watt (North America, non-flashing)
  Wagner 97
  Sylvania 97 (9.32 watt  nominal)
* 6 watt (flashing, non-North America)
License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
* 10 watt (Sedan, except North America)
* 7.5 watt Coupe, Van 26715-89901 Ichikho
* 7.5 watt Sedan USA
 Bailey B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
Reverse light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
24410.jpgAlbum 24410
* 26260-H1800 SOCKET-WITH LEAD WIRE
  BA9S/W6W socket
BULBS - G14 glass with BA9S/W6W base
* 26711-89900 BULB 1.7 watt (ROUND GAUGE)
  can use 1.9 watt Type 1445 Wagner 1445
* 26261-89900 3.4 watt (Square Gauge)
  Type 57
Lamp Specifications
Australia
1974 B120 Owner's Manual (Page 30 ... 30)
Bulb Chart
Head Lamp
26705-04101 Sealed beam unit (Koito)
or
26705-08700 Sealed beam unit (Koito)
Front Combination Lamp - Early
26717-89920 BULB (12V-23/7W)
26261-89900 BULB (12V-3W)
Front Combination Lamp - Late
26717-89900 BULB (12V-23) [P21W]
26261-89920 BULB (12V-8/3.4W) [P21/5W???]
* or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
  Spec. SAE No. Nissan^
Headlight unit 12V-50/40W 6012 26705-04201
Direction and Parking 12V-23/8W 1034/[*1157] 26717-89920
Side marker 12V-8W 67 26715-89902
License plate 12V-7.5W 89 26715-89901
Rear combo. Light
Taillight
Stop (brake)
Turn signal
Back-up light
12V-23/8W
12V-23/8W
12V-23W
12V-23W
1034
1034
1073/[**1156]
1073
26717-89920
26717-89900
Meter illumination 12V-1.7W (round gauge) 161 26711-89900
Wiper Knob illumination (1973) 12V-3.4W 158  ?
Heater control ill. (1973) 12V-3.4W 57  ?
Ignition warning 12V-1.7W 161 26711-89900
Turn Signal indicator 12V-1.7W 161 26261-89902
Headlight beam ind. 12V-1.7W 161 26711-89900
Oil press. warning 12V-1.7W 161 26711-89900
Brake warning 12V-1.7W 161 26711-89900
Room light 12V-10W n/a 26736-89902
^from USA catalog, all are ICHIKO brand
* 1157 can replace 1034 but uses more current
** 1156 can replace type 1073
1972 USA Owners manual (Page 36 ... ):
Bulb Chart
Portugal
Opticas 12V-50/40W
12V-21/5W Luz de mudança de direcção o de presença
12V-6W Luzes laterais de mudança de direcção
12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras
 12V-5W luz de presença
 12V-21W luz de stop (travões)
 12V-21W luz de mudança de direcção
 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos
12V-3W Luz avisadora da ignicão
12V-3W Luz indicadora dos máximos
12V-3W Luz avisadora da pressao do óleo
12V-10W Luz interior
12V-3W Luz de iluminação do relogió
