TS/Beam Switch Assembly (dimmer switch, flicker switch) is a key part of the Turn Signals system.
Connects To
The turn signal switch connects to:
- Steering Column
- Steering wheel. Specifically the pins on the bottom of the steering wheel hub cancel the turn signals when the wheel is turned
- Horn pad on the steering wheel, via the copper spring-action contact
The TS/Beam Switch mounts on the Steering Column, just behind the Steering wheel. It contains the turn signal lever stalk, cancelling mechanism and the Horn contact wiring.
Steering wheel cancelling pins
Standard switch SWITCH COMP-turn signal & dimmer 25540-H1007 B110 STD, B120 -7803 $155.78 USD * superceded 25540-H1006 25540-H1007L B120 (BENT ARM 10 DEGREE) 25540-HG007 B120 (STRAIGHT ARM)
passing switch type 25540-H1100 SWITCH COMP-turn signal & dimmer * OPTION DX, GL, GX * Optional on B120 -7803 * Standard on B120 7804-
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
ディマースイッチ ウィンカースイッチ
