Fog Lamps
Revision as of 00:49, 18 August 2021; view current revision
Category: Lighting System
<-- Back to: Lighting System
Fog Lights were an Option.
Datsun 1200
Factory Fog Lamps options for the B110 include
  • #H1012 Rectangular
  • H1014 Round 126mm diameter
  • H1016 Round 122mm diameter
  • H1018 Round 160mm diameter
  • #257 Round 160mm diameter
20634.jpgAlbum 20634 27847.pngAlbum 27847
b1101971companybrochure1.jpg b110071.jpg sunny1200_catalog_p2021.jpg img_254596_7869102_5x.jpg
26151-H1012
Stud-mount type with 'S' icon embossed in the glass
174_611c2c2b43092.jpgPost 495730 174_611c2c76bba60.jpgPost 495730 174_611c2c8582e6e.jpgPost 495730 174_611c2c91079b8.jpgPost 495730
174_611c2c176f781.jpgPost 495730
PB110
Datsun Sunny 1400 had the fog lamps built into the grille.
Aftermarket/Custom
11676.jpgAlbum 11676 21151.jpgAlbum 21151 21496.jpgAlbum 21496 48.JPGAlbum 48
Unknown -- found on 1200 with facelift grille
4124.jpgAlbum 4124 19867.jpgAlbum 19867
Datsun 1000
B10 Fog Lamp LENS 160mm
B10
* 89901 Ichikawa 35W (op.) ALL
* 18001 Ichikawa 35W (op.) ALL
* 18010 Koito sealed beam (op.) ALL
* 257 Koito 55W 160mm (op.) Coupe
* KB10#Sports Options iodine(沃素)
* KB10#Sports Options small
Ichiko 市光
Ichikawa 市川
Koito 小糸
26151-25710
174_611b7483beb32.jpgPost 20709
(optional) Coupe KB10
10 26150-25710 ASS'Y-LAMP, fog with bracket (小糸 Koito) (2)
   26750-89900 BULB 12V-55W (2)
   26151-25710 LENS (2)
   26152-25710 RIM (2)
Fog Lamps 26151-25710 LENS 160mm KOITO
20709.jpgAlbum 20709
Adjustable pivot
174_611b60c8cb31d.pngPost 495728
Datsun B210
Fog Lamps for B210 Grille
EARLY -1975
* ROUND
  26150-H5527 K-GX K-DX,K-GL OPTION > 26150-H5525 <> 26150-H5526
* RECTANGLE S,V OPTION
  26150-H5027 LAMP KIT-fog > 26150-H5025 <> 26150-H5026
25160-H6001 SWITCH COMP.-lighting with fog
LATE 1976-
LAMP KIT-FOG 30W bulbs (3-bolt type, sloping lens)
* top bolt centered
  25160-H5827 PB210 GX (op.)DX,GL > 25160-H5825 <> 26150-H5826
* top bolt offset
  26150-H7525 S.A14.GX *S.A12,A14-GX *V
  26150-H7526 K.A14.GX *K.DX,GL-L16
  26150-H7925 L16.GX *L16.GL
  26150-H7427 *S,V F/OKINAWA [lens differs from non-OKINAWA]
  26150-H7428 *K F/OKINAWA
  26150-H7926 *L16 F/OKINAWA
25160-H6001 SWITCH ASSY-LIGHTING W/FOG
25160-H5201 SWITCH ASSY-LIGHTING W/FOG&ILLUMI
25160-H5800 SWITCH COMP.-lighting with fog PB210 GX (op.)DX,GL
H55 Early Coupe
11320_4a64275c3fdc9.jpgUpload click to view
H58 PB210
737_54c21bb7b86e4.jpgPost 463127 19067.jpgAlbum 19067
Late Sedan (B211)
14242.jpgAlbum 14242 13864.jpgAlbum 13864 B211fl.jpg 17237.jpgAlbum 17237
Late Coupe (B211)
10994_4aefbc82e6507.jpgUpload click to view
H79 L16-powered (B211)
B110-style fog lamps on B210
24058.jpgAlbum 24058 4229.jpgAlbum 4229
B310
Round headlight B310 Grille only.
LAMP KIT-FOG IKI
26150-H8525 A12
26150-H8925 A14
25370-H8500 SWITCH ASSY-FOG LAMP
25375-S0100 KNOB-FOG LAMP SWITCH
LAMP ASSY-FOG RH
26150-H8500
* #S,K.A12S -7909
* #V.A12
26150-H8900
* K.GX #S.GX #W #DX,GL -7909
* #V.A14
A12
grille.jpg 174_58882cd75cc3f.jpgPost 483450
A14
'S' lamps - A12 grille
20639.jpgAlbum 20639 20640.jpgAlbum 20640
'NISSAN' lamps with adjuster - A14 grille
Aftermarket fog lamps fitted - Strap-fastened to the grille
174_588972636b78d.jpgPost 483480 174_588972bc0de34.jpgPost 483480
(SEV MARCHAL 750 759)
174_588972af27399.jpgPost 483480
Switch
フォグ ランプ
