B310 rear bumper
Revision as of 00:19, 29 August 2022; view current revision
Category: Datsun B310
<-- back to B310 Bumpers
Sunny B310 (1977-1982) came with several different style of bumpers
Small bumpers (one piece lightweight)
6320.jpgAlbum 6320 21554.jpgAlbum 21554
Large bumpers (rugged safety bumpers)
14430.jpgAlbum 14430 8853.jpgAlbum 8853
Large Bumper OPTION
174_5d8b1c21b4ce8.pngPost 492695
Large Bumpers
* Australia OPTION (no reverse lamps)
* Japan Wagon (reverse lamps in bumper)
* Japan OPTION for Sedan, Coupe (same as North America)
* North America all (reverse lamps in tailgate or combo lamp)
Small Bumpers
* Coupe, Sedan early type with number plate cutout
* Coupe, Sedan late type without cutout
* VB310 Van/wagon without number plate cutout
* GL, GX have rubber ends, others are plain chrome
Small Bumpers
The 'one-piece' bumpers are all-chrome units. The fancier trims have rubber end-covers bolted over the metal.
Early Small Bumpers
Early type locates the number plate below the bumper. Early cars also have round headlights.
Number plate cutout
* Wide for Australia, Holland, UK, etc.
* Narrow for Japan, Malaysia, etc.
174_5d7d8e9a8a102.pngPost 492595
  • H85 DX plain Sedan & Coupe. Also sedan Semi-DX
  • H89 GL/GX with rubber end-covers. Also longer brackets with a sight-shield to fill the gap between body & bumper
H85 Early DX style - all metal
22181.jpgAlbum 22181 10922.jpgAlbum 10922
H89 Early GL style - all metal. Differs by having 4 more holes in order to bolt on the rubber end-covers
sedan:
3391.jpgAlbum 3391 11948.jpgAlbum 11948 5533.jpgAlbum 5533 3916.jpgAlbum 3916
Coupe:
6305.jpgAlbum 6305 1148.jpgAlbum 1148
Europe:
k116127160zepcore-img450x600-1254468536dg396i75934.jpg k116127160zepcore-img600x450-1254468536przuxb75934.jpg
Late Small Bumpers
Late type locates the number plate above the bumper. Late cars are identified by square headlights (except Japan vans).
DX all-metal bumper (same as or similar to 85022-H9400 JDM Van)
GL Rubber-end bumper
* with lamps for license number plate
* without lamps for number plate
Late DX type - all metal
13567.jpgAlbum 13567
Late SGL type: rubber strip across bumper
Late GL - number plate LIGHTS above bumper
B310_1981-6_b.jpg 6035.jpgAlbum 6035
Late GL - number plate light IN bumper
14850.jpgAlbum 14850 7642.jpgAlbum 7642
Late DX
24714.jpgAlbum 24714 24718.jpgAlbum 24718 24773.jpgAlbum 24773
Sedan & Coupe
Late coupe (no cutout for licence plate}}. This version has the plate lights on the top edge of the bumper.
VB310
VB310 Van bumper has no cutout for number plate.
Small Bumper 85022-H9400
11701.jpgAlbum 11701 14964.jpgAlbum 14964 12342.jpgAlbum 12342
Van VS Sedan
small bumpers
* H94 Van
* H85 late Non-van
13567.jpgAlbum 13567 174_57e7067c31c18.jpgPost 481447
Japan Small Bumpers
TRIM
all metal    ES,CT,DX + Van
rubber ends  GL,GX,RSE
NUMBER PLATE CUTOUT
Van           no number plate cutout
Sedan, Coupe  narrow plate number cutout (Round Eye)
Sedan, Coupe  no number plate cutout (Square Eye)
Van 85022-H9400 Van
takuremi_sunny-img600x450-1305646211ad5ep657101.jpg saniwo2000-img600x450-1315720122jlgukf2137.jpg
Round Eye All metal 85022-H8500 DX,CT
f74268333akasrl311-img600x450-1227531832kwtsss12529.jpg m51627383hirakka-img600x450-1198906974dsc02065.jpg maina6000-img600x450-12826213856kp8xu36766.jpg
Round Eye Rubber-ended 85022-H8900 GL,GX & 85022-H8901 GL,GX
n63206471banbanbo2000-img600x450-1220170643ujekv549859.jpg k41994716youichi11221104-img600x450-1180671834dscn0488.jpg g64564908chk38750-img600x450-1219999197mxzcsk73736.jpg ysmat2008-img600x450-1291176224zdkh8y39211.jpg
Square Eye 85022-H8565 ES,CT,DX
f63591457funa710-img480x360-11998834562.jpg f66158356daddys_s-img600x450-1220672992vreeee74748.jpg k39548264arixcoltd-img600x450-1173438938p1060194.jpg m73111669sakuranbon_bon-img600x450-1263129715ken05y53619.jpg k108869318marutyosyouten-img600x450-12353643854spzrb27207.jpg
Square Eye 85022-H8560/85022-H8561 GL,GX - rubber strip at top
f69854632goos5555-img600x450-1229835883pg2lpz13282.jpg m49651272blacknight820002000-img600x450-1204209645dsc07199.jpg
Square Eye A14 OPTION - side-lit number plate
minorimn-img600x400-1277726772ktkstn76588.jpg r51797668ts_sunny310-img600x338-1234083902ky8yuo57225.jpg
Non-stock: Round-eye bumper (with plate notch) on Square-eye sedan (plate above bumper)
Luxe Bumpers
For 1980 the the GL/GX bumper was rationalized to use less expensive parts. Instead of using the all-metal bumper and adding rubber finishers to it, it changed to a shorter bumper bar with rubber end extensions.
GL
This used specimen has a center sticker "ひろびろサニー" Spacious Sunny
174_63081619ead90.jpgPost 497110 174_630816250d920.jpgPost 497110
174_6308162fa82bd.jpgPost 497110
End finishers
28623.jpgAlbum 28623
This bumper has a sticker on the right "サニー宮城" (Sunny Miyagi)
174_630816394c6f8.jpgPost 497110
SGL
Late SGL had a fat rubber overrider along the top half of the bumper bar
28585.jpgAlbum 28585
end caps are bolted on to the lightweight bar
28586.jpgAlbum 28586
SGL end caps are extra long
28587.jpgAlbum 28587
SGL rubber end caps have three sections, divided by two horizontal lines
28588.jpgAlbum 28588 28589.jpgAlbum 28589
End Caps
The one-piece bumper is fitted with rubber end caps on GL & GX B310s.
Rear Bumper end finishers (late bumper from October 1979)
85030-H8560 BUMPER-REAR RH 7910-
85031-H8560 BUMPER-REAR LH 7910-
The small (one-piece) bumper is differentiated by the shape of the end caps
The large bumper (three-piece) bumper:
  • front: diagonal-cut end caps
  • rear: end caps with two horizontal lines
Stays
28593.jpgAlbum 28593
Rear bumper stay 85210-H8805 for which bumper?
ステー,リヤ バンパー
85212 STAY-REAR BUMPER RH
85213 STAY-REAR BUMPER LH
  85201-H9401 Van
  85211-H8500 K.DX               -7909
              S.CT,DX            -7811
              S.DX,DT,CITYDX 7812-8010
  85211-H8501 K.ES           8011-
              S.CT,DX        8011-
  85211-H8900 K.GL,GX#           -7909
              K.GS,GX,RSE    7910-
              S.GL,GX#           -7909
              S.GL#,GX       7910-
  85211-H9310 W
H89
Luxe type (GL/GX/GS/RSE). These long stays space the bumper out from the body. The bumper then needs a sight shield which bolts to the stay. Used with the one-piece H89 bumper (early years) and then with the shorter H856 bumper bar (later years).
With H89 stainless bumper (early Luxe)
28613.pngAlbum 28613
85211-H8900 STAY-REAR BUMPER LH
85212-H8900 STAY-REAR BUMPER RH
With H8561 bumper (late Luxe)
28614.pngAlbum 28614
Large Bumper
Large Bumper OPTION — safety bumpers meeting 5mph crash standard
Large bumpers use a channel-shaped stamping. The ends are all plastic (there is no metal underneath the plastic)
  • Large bumpers have no cutout for number plate
  • No number plate lamps in bumper, but use a side-lit plate
  • No reverse lamps in bumper (except JDM California wagon)
Australia | Malaysia
14692.jpgAlbum 14692 10514.jpgAlbum 10514
Shock-absorber mounts
22908.jpgAlbum 22908 22907.jpgAlbum 22907
Japan Large Rear Bumper
#WB310 with reverse lamps
* 85022-H9800 Wagon round-eye  7901-7909 (no overriders)
* 85022-H9905 Wagon square-eye 7910- (strip overrider)
JDM OPTION for Sedan, Coupe (shock absorbed park-bench type)
* Same as USA spec bumpers
* 85022-H9100 Round Eye (late) 7812-7909
* 85022-H9900 Square Eye 7910-
WB310
WB310 Wagon has large park-bench style bumper
  • reverse lamps in bumper for Japan
  • reverse lamps in tailgate for other markets
AUS | Japan
6778.jpgAlbum 6778 e86542521carogon_6666-img600x450-12261215557ne6i221743.jpg
JDM #WB310 with reverse lamps
JDM Wagon round-eye 85022-H9800 7901-7909 no overriders
JDM Wagon square-eye 85022-H9905 7910- strip overrider
e86542521carogon_6666-img600x450-12261215557ne6i221743.jpg d93944329ssyoshi17-img600x450-1238852534yv4alm33363.jpg
North America
North America used same bumper for all models (Sedan, Wagon, Coupe same). It is a large 5 mph crash-resistant shock-absorbing type. Just like the Japan OPTION bumper, except there are no reverse lamps in the North American bumper.
Round Headlamp cars use rubber overriders
Square Headlamp cars use rubber strip
Round Headlight -1179
 62050-H9100 OVER RIDER-BUMPER
 85022-H9100 BUMPER CENTER-REAR -0779
 85022-H9901 BUMPER CENTER-REAR 0879-1179 <> 85022-H9100
Square Headlight 1279-
 85060-H9900 RUBBER STRIP ASSY-FRONT
 85022-H9900 BUMPER CENTER-REAR
 85022-H9930 BUMPER CENTER-REAR <> 85022-H9900
Round Headlight (two overiders) Bumper is same as JDM OPTION
Datsun-B210-9.jpg Datsun-B210-10.jpg Datsun-B210-11.jpg 6355.jpgAlbum 6355 8853.jpgAlbum 8853 23889.jpgAlbum 23889
Square Headlamp (strip overrider) same as JDM OPTION
B3101980ToughEnough.jpg 14430.jpgAlbum 14430
Rear bumper removal shows the shock absorbers
22907.jpgAlbum 22907 22908.jpgAlbum 22908
85022-H9930
JAPAN option safety bumper
28590.jpgAlbum 28590 28591.jpgAlbum 28591 28592.jpgAlbum 28592
Fiberglass
