Heated Glass
Revision as of 01:54, 23 July 2025; view current revision
Category: Body
Heated rear glass (electric rear defroster/defogger/demister) was an option for Sedan & Coupe. Canada 1200s included it as standard equipment.
heat+glass1200
11441.jpgAlbum 11441 14968.jpgAlbum 14968
1972 facelift dash
174_5b98f0e02302b.jpgPost 489434
Factory electrical grid wires (horizontal lines)
83.jpgAlbum 83
Aftermarket electrical grid wires (vertical lines)
28706.jpgAlbum 28706
Operation
1972 USA Owners manual (Page 13 ... ):
HEAT GLASS SWITCH (Optional)
The rear heat glass incorporates a printed heating element to prevent frosting or icing. To heat the rear glass pull out on the glass heat switch with the ignition switch placed in the "ON" position. A pilot lamp glows when the switch is pulled out.
27150.jpgAlbum 27150
Switch
The switch is bolted to the bottom edge of the dash, to the side of the steering wheel. A pilot lamp glows when the switch is pulled out.
25230-H2200 SWITCH-HEAT GLASS OP. 1270-
08510-51212 SCREW Tapping, Pan head 2 OP. 1270-
1681.jpgAlbum 1681 28693.jpgAlbum 28693 28694.jpgAlbum 28694 28695.jpgAlbum 28695 28696.jpgAlbum 28696
Extra wires added. Purpose of the small green lights is unknown
28697.jpgAlbum 28697
With 14mm LED fitted. The bezel is slightly different
28698.jpgAlbum 28698 28699.jpgAlbum 28699 28700.jpgAlbum 28700
wiring mods: extra tap with Y wire, B earth wire
28701.jpgAlbum 28701 28702.jpgAlbum 28702 28703.jpgAlbum 28703
original BL wire harness with fuse
28704.jpgAlbum 28704
with original Lamp and connector
28705.jpgAlbum 28705
リア ヒートガラス スイッチ
ACC on the Ignition Switch feeds the rear defroster.
22163.jpgAlbum 22163
Sedan rear-glass wiring
12960.jpgAlbum 12960
Parts
Switch Part Numbers , Rear Window Part Numbers
OPTIONAL COUPE, 4-door SEDAN including PB110
#25230-H2200 SWITCH-HEAT GLASS 1270-
#08510-51212 SCREW 2 OP. 1270-
79713-H2200 GLASS-rear window Coupe
79713-H2900 GLASS-rear window Sedan
24161-H2200 CABLE ASS'Y-rear heat glass A
24162-H2200 CABLE ASS'Y-rear heat glass B (l=400mm) Sedan
24163-H2200 CABLE ASS'Y-rear heat glass C (l=350mm) Coupe
