TS/Beam Switch Assembly (column-mounted stalk dimmer switch/flicker switch) is a key part of the Turn Signals system.
Connects To
The turn signal switch connects to:
- Steering Column
- Steering wheel. Specifically the pins on the bottom of the steering wheel hub cancel the turn signals when the wheel is turned
- Horn pad on the steering wheel, via the copper spring-action contact
The TS/Beam Switch mounts on the Steering Column, just behind the Steering wheel. It contains the turn signal lever stalk, cancelling mechanism and the Horn contact wiring.
Steering wheel cancelling pins
Standard switch SWITCH COMP-turn signal & dimmer 25540-H1007 B110 STD, B120 -7803 $155.78 USD * superceded 25540-H1006 25540-H1007L B120 (BENT ARM 10 DEGREE) 25540-HG007 B120 (STRAIGHT ARM)
passing switch type 25540-H1100 SWITCH COMP-turn signal & dimmer * OPTION DX, GL, GX * Optional on B120 -7803 * Standard on B120 7804-
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
The B210 indicator/high-beam switch has differences from the 1200 switch. It has the same 6-pin large connector but often only 4 pins are connected. It has a 2nd square 4-pin connector for the dimmer wires, which on the 1200 are in the large connector.
It looks very similar to the 1200 unit, and fastens to the column same way with two bolts, however it is unknown if it will bolt up to the 1200 column.
25540-H5000 with large connector having 4 or 6 pins 25540-H5010 7624A 4-pin large connector 25540-H5300 superceeds H5000
B210 electrical connectors differ (small square connector instead of three individual wires)
The Horn ring contact arm is facing the opposite direction compare to the 1200
The two clamping screws are facing the opposite direction compared to the 1200 swith
ディマースイッチ ウィンカースイッチ
