Glovebox
Revision as of 02:48, 7 June 2025; view current revision
Category: Body
<-- back to Dashboard
The Glove Box is also known as the glove compartment or cubby-hole takes up the passenger side of the Dashboard. Datsun 1200 uses a closing glovebox, with a hinged door (lid or cover). There are two areas to place cups on the inside of the lid.
NOTE: B210 glovebox does not fit the B110.
30413.jpgAlbum 30413
Latched door | Latchless door (held closed by spring pressure)
13439.jpgAlbum 13439 26012.jpgAlbum 26012
RHD glove boxes
978.jpgAlbum 978 223.jpgAlbum 223
LHD with latch
13439.jpgAlbum 13439 13440.jpgAlbum 13440
Box
The glove box is made out of heavy card stock, and stapled together. 3 pieces of card with 2 strips reinforcing the top and bottom edges.
26314.jpgAlbum 26314 26315.jpgAlbum 26315
Top edge: metal (riveted on). Bottom edge: paper (stapled on)
26941.jpgAlbum 26941 26942.jpgAlbum 26942 26943.jpgAlbum 26943
Lid
EARLY GLOVE BOX LID
H10 Black DX,GL,GX
H26 Blue  GL
H27 Brown GX
Latchless style (JDM 1200s & early Australia)
1977_B120_dash-4.jpg 25982.jpgAlbum 25982 25980.jpgAlbum 25980
5046.jpgAlbum 5046
LHD latched style
willieoec-img600x450-1327300031bip0ro50055.jpg willieoec-img600x450-1327300032fwubvu50055.jpg willieoec-img600x450-1327300032q2ccux50055.jpg 25981.jpgAlbum 25981
1972 USA key code sticker
13443.jpgAlbum 13443
1972 USA tire inflation sticker
13442.jpgAlbum 13442
1972 Lid
For the 1972 JDM facelift the lid cover was restyled. The hinge and inside appears to be a continuation.
174_5d658bb70b99d.jpgPost 492387 174_5d658bc14768c.jpgPost 492387 174_5d658bcd55d72.jpgPost 492387
Lid Hinge
174_5d66445c3a807.jpgPost 492395 174_5d66446d4e7e4.jpgPost 492395
Hinge detail. If often wears away the box material.
13441.jpgAlbum 13441
If the lid becomes loose, repeated use will start tearing the dash-pad material.
174_5d664453eb012.jpgPost 492395
BOX - LHD/RHD same
68960-H1000 ASSY-BOX GLOVE $17.17 USD
LID - LHD
68920-H1900 ASSY-LID GLOVE BOX LHD $60.85 USD
LID - RHD JAPAN LID-GLOVE BOX
68920-H1000 7001-7803 BLACK (including PB110 DX/GL/GX)
68920-H2600 PB110 GL BLUE
68920-H2700 PB110 GX BROWN
68920-H3100 1972 FACELIFT 'SUNNY'
68920-G1060 7804-8910 BROWN
68920-95W00 8910-9403 GRAY
LHD hardware
62285-61500 SCREW [holding lid back to lid] (6)
68929-H1600 SPRING G/BOX LID LHD
68927-H1000 GUIDE-GLOVE BOX LID STOPPER
68928-H1900 RING-STOPPER
08310-41662 SCREW-MACHINE M4 (2)
68826-H1000 WASHER-PLAIN (2)
08964-10510 NUT-SPRING (2)
08533-41242 SCREW-TAPPING M4 (2)
RHD hardware
68927-H1000 GUIDE-glove box lid, stopper
68929-H1002 SPRING-glove box lid
68825-61500 BUMPER-rubber (2) RHD
68928-H1000 STOPPER-check link (rubber) RHD
68929-H1002 SPRING-glove box lid RHD
08310-41691 SCREW (2)
68826-H1000 WASHER-plain (2)
08964-10510 NUT-lock (2)
1970-1971
* 08533-41212 SCREW (2)
1972
* 08540-51612 SCREW (2)
30412.jpgAlbum 30412
Original vs 1972
For the Japan domestic market, the glovebox was re-designed to match the 1972 Dashboard
13486.jpgAlbum 13486
H31 1972 Facelift
25979.jpgAlbum 25979
H19 left-hand-drive
Brown
174_5d6592df84b8e.jpgPost 492388 174_5d65936122e22.jpgPost 492388
グローブボックス グローブボックスカバー
Latchless Door
RHD style #2 - Latchless door
174_5d64e85694836.jpgPost 492386 174_5d64e864bf0ef.jpgPost 492386 174_5d64e86d78a45.jpgPost 492386 13434.jpgAlbum 13434
