Steering Linkage
Revision as of 04:45, 15 February 2009; view current revision
Category: Steering System
The Datsun 1200 uses a tradition recirculating-ball Steering Gearbox with behind-the axle linkage.
Terminology
  • 1. Idler Arm. This bolts to the subframe rail on opposite side from the steering gearbox
  • 9. Steering Gear Arm, a.k.a. "Pitman arm"
  • 19,20. Side Rod, a.k.a. "tie rod". Left and right hand differ
  • 12. Cross Rod, a.k.a. "drag link" or "center link"
  • 21, 22, 23, 24. Side Rod Socket Ass'y a.k.a. "tie rod ends". There are four separate parts with left and right-hand threads. Each "socket" has a "ball stud", which is similar to a Ball Joint.
The six ball studs have a Filler Plug on the bottom of each. Replace it with a grease fitting and fill it during each periodic "lube, oil and filter".
Power Steering
Sunny Trucks had optional power steering:
Idler Arm
Idler Arm Bushing
Cross Rod
The Cross Rod is also known as center link or drag link.
  • 48560-H1600 ASSY-CROSS ROD STEERING USA B110
  • 48560-H1000 ROD ASS'Y-CROSS JDM B110, B120 (all years)
    RHD B110 top, B210 bottom:
B10
  • B10: 48545-18001 BUSHING-idler shaft
  • 48560-H6200 ASSY-CROSS ROD LHD USA
    4401036-1.jpg Rock Auto
  • 48560-H2500 ROD ASS'Y-CROSS PB110, PB210
  • 48560-H5025 ROD ASS'Y cross steering RHD JDM
    RHD B210 bottom, B110 top:
B310 (and A10)
  • 48560-W5725 ROD ASSY-CROSS,STEERING North America B310, A10
  • 48560-W5025 ROD ASSY-CROSS JDM B310, A10
