Air conditioning
Revision as of 04:11, 15 August 2009; view current revision
Datsun 1200, unlike the Datsun 1000, was designed with airconditioning in mind. However, it was still a dealer-installed add-on option.
  • Pump
  • Condensor (cooling radiator)
  • Double crankshaft pulley. (The extra pulley runs the compressor)
  • Under-dash vents
  • Hoses
  • Wiring
Since B110 A/C is fairly rare, you can source most of the parts from a B210 or B310. Only the interior vent setup is needed for a B110. They are fairly common on late model B122 Sunny Trucks.
Optional Fan
Nissan option flex-fan
Dealer item
From USA catalog:
  • 21060-H1001 FAN-COOLING A12 (standard B110 fan)
  • 21060-A4605, 21060-N0100 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter)
B122 Sunny Truck Kit
You need all these parts:
  • Ass'y indoor unit (air volume switch, evaporator, integrated blower fan)
  • air conditioner compressor
  • compressor bracket
  • crank pulley (belt cooler)
  • two capacitor (before radiator, radiator horizontal)
  • capacitor for electric fans
  • high-pressure pipe
  • low-pressure hose
  • Receiver tank
  • relay harnesses
2185.jpg 2187.jpg 2199.jpg 2209.jpg 2210.jpg 2341.jpg 2495.jpg 3053.jpg 3811.jpg 4163.jpg 4164.jpg 4305.jpg 5060.jpg 5063.jpg 7777.jpg 9377.jpg 9378.jpg 11444.jpg 12038.jpg 13181.jpg 13934.jpg 14556.jpg 14557.jpg 14950.jpg 14953.jpg 15192.jpg 15193.jpg 15194.jpg 15622.jpg 16243.jpg 16244.jpg 17263.jpg 17654.jpg 17655.jpg 18256.jpg 18710.jpg 18767.jpg
