Sedan Grille
Revision as of 07:53, 12 May 2009; view current revision
Category: Body
Datsun 1200 Sedans were fitted with a stainless metal grille. 1200 Pickups from 1971-1977 use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Also see: Grille Overview, Badges
Original Grille
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
  • Japan market 1200s used "S" mark
  • Export market 1200s used "D" mark
Fitting
Click for full size pictures of the grille mount points:
And the eyebrow trim mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to nearly all Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit it to a Coupe.
  1. Fit one L-shaped bracket to center top of front body. The top of bracket should be 1/8" from top of ledge.
  2. Fit two thin brackets to back of sedan grille
  3. Drill four holes in radiator support to correspond to the holes in the sheet bracket
    • Drill them 20mm to the side of the headlight rim screw holes
  4. Screw sheet loops to front of car
  5. Screw grille to sheet loop ends
Fit the headlight Rims (easiest to do with grille off car)
  1. coupe and late ute are missing the outer bracket:
  2. All core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
    96706-B0700 GROMMET for screw
  • Grille (1-3)
    62302-H1003 ASS'Y-grille, radiator Sedan (exc. GX), Van, Truck -7803 $169.65 USD
    62302-H2300 ASS'Y-grille, radiator Sedan GX
  • 96706-B0700 SCREW-grommet (4 total) $1.00 USD
    85-10410-4 SCREW (4 total)
  • Center Badge (4-7)
    62312-H1026 SET-ORNAMENT, radiator grille ['S']
    62312-H1626 SET-ORNAMENT, radiator grille ['D'] $16.80 USD
    • 89-15434-1 WASHER-plain (2)
    • 89-15134-1 WASHER-lock (2)
    • 89-11104-1 NUT (2)
  • Grille side emblem (8-13)
  • Eyebrow Trim (head lamp Rim) (14-19)
    62320-H1002 ASS'Y-RIM, head lamp (R.H) $39.17 USD
    62321-H1002 ASS'Y-RIM, head lamp (L.H) $39.17 USD
    • 85-30412-9 Screw: Stainless outside (1 per side)
      96706-B0700 SCREW-grommet [square-hole wedgie](2 per side)
    • 85-30412-9 SCREW (1 per side)
      89-64104-4 NUT-spring (1 per side)
  • Surround Trim (20-25) Coupe, Sedan and Van
    62322-H1001 SURROUND-radiator grille, upper $40.27 USD
    • Attaches to hood/bonnet
    • 85-40410-12 SCREW (6 needed)
    62323-H1001 SURROUND-radiator grille, lower $27.13 USD
    • 85-40410-9 SCREW (10 needed)
    62324-H1051 SURROUND-radiator grille, side with rubber (R.H) $29.50 USD
    • 4 screws, unlisted in catalog
    62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side)
    62325-H1051 SURROUND-radiator grille, side with rubber (L.H) $29.50 USD
Core Support Panels
Radiator Core Panel (Applies to Sedan including 1972 facelift, Van, and Truck -7803)
  • 62500-H1000 ASS'Y-SUPPORT, radiator core
    • Coupe differs (H18)
  • 62512-H1000 RAIL-support, radiator core, upper
  • 62524-H1000 PLATE-closing rod (optional)
    Also listed as COVER ASSY-COOLING HOLE Truck -7803
    • 62524-51012 SCREW (4)
  • 62522-H1001 STAY-hood catch
  • 62612-H1000 PLATE-apron front
  • 77720-89908 SCREW (4)
  • 63140-78500 NUT(4)
1972 Minor Facelift
The 1972 JDM facelift introduced a new grille for sedans.
Retro-fitted to newer Sunny Truck:
Emblems
Late JDM intricate "S" grille emblem
