Datsun 1200 Sedans were fitted with a stainless metal grille. 1200 Pickups from 1971-1977 use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Also see: Grille Overview, Badges
Original Grille
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
- Japan market 1200s used "S" mark
- Export market 1200s used "D" mark
Fitting
Click for full size pictures of the grille mount points:
And the eyebrow trim mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to nearly all Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit it to a Coupe.
- Fit one L-shaped bracket to center top of front body. The top of bracket should be 1/8" from top of ledge.
- Fit two thin brackets to back of sedan grille
- Drill four holes in radiator support to correspond to the holes in the sheet bracket
- Drill them 20mm to the side of the headlight rim screw holes
- Screw sheet loops to front of car
- Screw grille to sheet loop ends
Fit the headlight Rims (easiest to do with grille off car)
- coupe and late ute are missing the outer bracket:
- All core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
- Grille (1-3)
- 62302-H1003 ASS'Y-grille, radiator Sedan (exc. GX), Van, Truck -7803 $169.65 USD
- 62302-H2300 ASS'Y-grille, radiator Sedan GX
- 96706-B0700 SCREW-grommet (4 total) $1.00 USD
- 85-10410-4 SCREW (4 total)
- Center Badge (4-7)
- 62312-H1026 SET-ORNAMENT, radiator grille ['S']
- 62312-H1626 SET-ORNAMENT, radiator grille ['D'] $16.80 USD
- 89-15434-1 WASHER-plain (2)
- 89-15134-1 WASHER-lock (2)
- 89-11104-1 NUT (2)
- Grille side emblem (8-13)
- Eyebrow Trim (head lamp Rim) (14-19)
- 62320-H1002 ASS'Y-RIM, head lamp (R.H) $39.17 USD
- 62321-H1002 ASS'Y-RIM, head lamp (L.H) $39.17 USD
- 85-30412-9 Screw: Stainless outside (1 per side)
- 96706-B0700 SCREW-grommet [square-hole wedgie](2 per side)
- 85-30412-9 SCREW (1 per side)
- 89-64104-4 NUT-spring (1 per side)
- Surround Trim (20-25) Coupe, Sedan and Van
- 62322-H1001 SURROUND-radiator grille, upper $40.27 USD
- Attaches to hood/bonnet
- 85-40410-12 SCREW (6 needed)
- 62323-H1001 SURROUND-radiator grille, lower $27.13 USD
- 85-40410-9 SCREW (10 needed)
- 62324-H1051 SURROUND-radiator grille, side with rubber (R.H) $29.50 USD
- 4 screws, unlisted in catalog
- 62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side)
- 62325-H1051 SURROUND-radiator grille, side with rubber (L.H) $29.50 USD
Core Support Panels
1972 Minor Facelift
The 1972 JDM facelift introduced a new grille for sedans.
Retro-fitted to newer Sunny Truck:
