Datsun 1200's A12 engine uses a traditional type of starter motor with a Bendix gear drive. The Aftermarket Bosch starter motor is far better the the orgiinal specification Datsun 1200 starter. The newer Datsun starter by Mitsubishi or Hitachi from B210 or B310 is good too and will fit the Datsun 1200's A12 engine.
A-series Engine Starting motor (hitachi or mitsubishi)
- All have 9-tooth gears
- If you place the solenoid at the top (12:00 o'clock)
- The bottom bolt will be at 6:00 o'clock
- The top bolt at 1:00 o'clock
B10 Hitachi (2-brush)
- 23300-18000 ASS'Y-starter HITACHI 5114-87 B10
- 23300-18005 ASS'Y-starter HITACHI 5114-87K (ISO threads) B10 interchages with 23300-18000
- 23300-H0100 ASS'Y-starter HITACHI 5114-87L B10 supercedes 5114 models
B10 Mitsubishi (3-brush)
- 23300-18010 ASS'Y-starter Mitsubishi MW-V1R B10
- 23300-18011 ASS'Y-starter Mitsubishi MW-V3R B10 interchanges with MW-V1R
- 23300-18015 ASS'Y-starter Mitsubishi 206-893 (ISO threads) B10 interchanges with MW models
B110 Hitachi (2-brush)
- 23300-H0101 ASS'Y-starter Hitachi S114-87M B110 manual transmission
- Weight: 10.1 pounds
- Torque: 6.5+ lb-ft
- Brush length: 16 mm (new), 6.5 mm (service limit)
- 23300-H3900 ASS'Y-starter Hitachi S114-156 B110 automatic transmission
- Weight: 11.9 pounds
- Torque: 7.2+ lb-ft
- Brush length: 14 mm (new), 4.5 mm (service limit)
- Easily identifiable by the removable band on the case (bottom of this photo):
- Replaceable brushes (held in by screws)
- 1.0 KW output
B110 Mitsubishi (4-brush)
- 23300-18015 ASS'Y-starter Mitsubishi MW-V3R (Same as B10 part number)
- 23300-18016 ASS'Y-starter Mitsubishi MW-V5R (from 72-5) supercedes MW-V3R type
B210 manual transmission
- 23300-H0101 ASS'Y-starter Hitachi S114-87M B210 A12 M/T
- 23300-H5000 ASS'Y-starter Hitachi S114-87P B210 A12 (from 73-6) M/T
- 23300-H5001 ASS'Y-starter Hitachi S114-160 B210 A12 (from 74-4) M/T (4-brush)
B210 Automatic transmission
- 23300-H3900 ASS'Y-starter Hitachi S114-156 B210 A12 A/T
- 23300-H6900 ASS'Y-starter Hitachi S114-156A B210 (from 73-6) A12 A/T
- 23300-H6901 ASS'Y-starter Hitachi S114-163 B210 (from 74-4) A12 A/T (4-brush)
Strict interchange:
- Manual Transmission
- 23300-H5000, H5001, H7301 (Hollander 1217)
- All Sunny 1971-1979 Manual Tranmission
- (what about 1980-1982?)
- What about Datsun 1000?
- Hollander 1395 fits if you swap the drive gear
- Automatic Transmission
- Part number?
Reported interchange: All A-series. Auto or Manual.
- 23300-H0100, 23300-H6901, 23300-H0101, 23300-H6903
23300-08700, 23300-H5003, 23300-H0510, 23300-H6904, 23300-18000,
23300-H5004, 23300-H0511, 23300-H7300, 23300-18005, 23300-H5010,
23300-H3900, 23300-H7301, 23300-18015, 23300-H5011, 23300-H5000,
23300-H7302, 23300-18016, 23300-H6900, 23300-H5001, 23300-E3000
Reduction Starter
1977 Canada models and 1978-up USA models used an optional Reduction gear starting motor with increase torque for easy starting in sub-zero temperatures. This is also a good upgrade for high-compression engines. On the B210 it requires a different right-side engine mount.
Details on fitting this to a Datsun 1200 are needed. Can it be done?
Forklift Starter
PitRoad Reduction Starter
Pitroad for 1971-1973
For 1974-up utes, cut a bit of the right-side tower like this:
Service
Starter parts breakdown for original (2-brush) Datsun 1200 starter
- The brushes can be replaced with a large soldering iron
- The overrun cluch (drive gear) can easily be replaced
Otherwise, replace with a new, rebuilt or good used unit.
Check Gear Teeth
- Check gear teeth for nice, consistent chamfer, as shown here.
- Teeth worn flat with destroy a good flywheel (and vice-versa)
Testing Overrun Clutch
If your starter "whizzes" just after the engine catches, the Overrun clutch is almost for sure bad. If you do not replace it, eventually it will wear so much it free spings, instead of turning the engine.
- Remove starter from engine
- With your fingers, turn the small drive gear.
- It should smoothly turn one direction
- It should NOT turn at all the other direction, not even a little bit
Check Bushing
Brushes
Remove the brush cover or end cap. Inspect the brushes.
- original type with brush band: Brushes unscrew and can be easily replace
- newer more powerful starters: although you can buy new brushes, it is a heavy-duty soldering job to replace them.
Solenoid
If the starter just 'clicks' but doesn't turn the engine, it is probably a low battery, or dirty wiring. It that check out, your solenoid may be dirty. Unlike other brands, the A-series solenoids have soldered connections and are not designed to be disassembled and cleaned.
