Datsun 620 Truck shares some parts with Datsun 1200
Applied Model
Any Nissan Part Numbers for 1200 that have this applied model code xxxxx-NNNxx are likely to be found in a 620 truck, where NNN is:
- B50: Datsun 620 RHD
- B93: Datsun 620 Truck RHD 7510-
- B94: Datsun 620 Truck RHD 7605- Custom [extended cab]
- B95: Datsun 620 Truck RHD
- B96: Datsun 620 Pickup (coupe utility)
- B64: Datsun 620 pickup LHD
- G70:
- G71: Datsun 620 Truck RHD 7809-
Desirable Parts
- 1979 Wiper Switch for Intermittent Wipers
- 1979 Wiper AMP
- 1974-1979 Wiper Switch (lighted type) can be adapted same as the intermittent type
- Black interior Door escutcheons (will replace 1200 chrome ones)
- Fuse Box
- 1979 35A Alternator with Internal Regulator (bolt in upgrade for B110)
- Bucket seats -- thin B210 style, fits 1200 utes nicely
Engine
- 12308-H1000 WASHER-PULLEY CRANKSHAFT J15 ENGINE 7602-
- 13231-H1001 LIFTER-VALVE J15
- 14006-18000 [B10] PIN [for J15? intake manifold]
- 14026-18001 WEIGHT-COUNTER HEATER CONTROL J15 [exhaust manifold heat riser]
- 14022-18000 SPRING-HEATER CONTROL J15
- 15208-H1010 ELEMENT-OIL FILTER J15
- 21200-H7802 THERMOSTAT 76.5C
- 21480-18000 COCK-WATER DRAIN RADIATOR J15 -7612
- 21481-18000 PACKING-DRAIN RADIATOR J15 -7612
- 21482-18000 SEAT-DRAIN RADIATOR J15 -7612
- 18221-H5005 [B210] BRACKET-WIRE ACCELERATOR J15 -7708 [throttle cable bracket]
- 18415-H1001 KNOB-CHOKE CONTROL
Fuel
- 17103-H7260 [B210 A14] CONNECTOR ASSY-FUEL INLET J15 [right angle fuel pump inlet]
- 17103-H5310 [B210] CONNECTOR ASSY-FUEL OUTLET J15 [right angle fuel pump OUTLET]
- 16331-H1000 COMPENSATOR-IDLE [air cleaner compensator valve]
- 16335-H5700 ORIFICE-A AIR CLEANER TUBE
- 16547-H1000 PACKING [air cleaner-to-air filter gasket (2 needed)]
- 16546-18000 ELEMENT ASSY [air filter]
- 16548-18000 PACKING [air cleaner lid-to-base gasket]
- 16568-H1000 PACKING [air cleaner nut gasket]
- 17515-H5501 HOSE-BREATHER -7801 L=360 [tank to reservoir]
- 17515-H5510 HOSE-BREATHER -7801 L=625 [tank to reservoir]
- 17515-H5506 HOSE-BREATHER -7801 [filler tube to reservoir]
- 17515-H5502 HOSE-BREATHER -7801 L=300 [tank to reservoir]
- 17342-18000 RING-O FUEL GAUGE
Power Train
- 30610-H5802 [B210] CYLINDER ASSY-CLUTCH MASTER 5/8 7603-
- 30631-H5801 [B210] ROD ASSY-PUSH 7603-
- 41128-18000 SCREW-BLEEDER TOKICO [clutch slave]
- 46206-18000 SPRING-LOCK [clutch slave line bracket clip]
- 63-series 4-speed parts (bearings, perhaps synchros)
620 Pickup (Ute)
- 17310-H1000 PLUG-DRAIN [fuel tank]
- 17312-H1000 PACKING-DRAIN PLUG [fuel tank]
Brakes
- 36437-18000 NUT-ADJUSTING [rear left emergency brake line, at center pivot]
- 41158-18000 PACKING-CONNECTOR FRONT BRAKE -7708 [for front brack hose ay cylinder]
- 44112-H3300 CUP-PISTON REAR BRAKE 11/16 NABCO 7709-
- 44112-H3310 CUP-PISTON REAR BRAKE 11/16 TOKICO 7709-
- 44158-18000 PACKING [brake line to cylinder]
- 46512-H0101 STOPPER-RUBBER [brake pedal]
- 46510-18000 STOPPER-PEDAL [brake pedal]
- 46525-18000 BUSH-PEDAL -7904
- 46206-18000 SPRING-LOCK BRAKE HOSE -7708
- 46234-H1100 CONNECTOR-BRAKE TUBE
- 46313-18000 CONNECTOR-BRAKE TUBE -7708
Chassis
- 40038-H1000 BOLT-STOPPER [knuckle arm stop]
- 43067-H0100 STUD -7805 [axle housing to carrier studs]
- Steering wheel looks similar
- 54472-18000 WASHER-THRUST TENSION ROD 7709-
- 54481-18000 BUSHING MOUNTING TENSION ROD 7709-
- 54630-H1001 COLLAR-TENSION ROD 7709-
Electrical
- 22136-H2300 PLATE ASSY-BREAKER HITACHI J15
- 22157-H1000 ROTOR-HEAD HITACHI J15
- 22157-18010 ROTOR-HEAD MITSUBISHI J15
- 22403-18005 TERMINAL ASSY HITACHI J15
- 22750-H2300 SCREW KIT HITACHI J15 [distributor]
- [B210] Alternator LT135 Hitachi
- [B210] Alternator LT150 Hitachi
- [B210] Alternator Mitsubishi
- 25442-H2500 LINK-FUSIBLE
- Gauge Cluster looks similar
- Tachometer same, but direct wired
- Speedometer looks same
- 26260-H1800 SOCKET ASSY-BULB F/TURNSIGNAL
- 24815-H3121 RELAY-BUZZER
- 25165-H1000 KNOB-LIGHTING SWITCH
- 25230-H1604 RELAY ASSY-WATER TEMPERATURE F/WATER TEMP -7603
- 25230-H6203 [B210] RELAY ASSY-EGR CUT -7708
- 25265-H1000 KNOB-WIPER SWITCH
- 25320-H1000 SWITCH ASSY-STOP LAMP
- 27450-H6200 [B210] BRACKET ASSY-TANK 7708- [radiator overflow]
- 27480-H1001 TANK ASSY-WINDSHIELD WASHER
- Radio
- Speakers
- 27962-H1100 ANTENNA -7612
- B9200-H1000 STEREO KIT-CARTRIDGE [8-track tape]
- Clock look similar
- 27640-H1001 TANKS ASSY-LIQUID DKKC [air con]
- Air con, some parts fit B210
- 22137-H1000 KNOB-CONTROL LOWER NICHIRA [heater]
- 22138-H1000 KNOB-CONTROL UPPER NICHIRA [heater]
Pickup (uses VB110 wagon rear lights)
- 26551-H1401 LENS-COMBINATION LAMP RH
- 26556-H1401 LENS-COMBINATION LAMP LH
- 26550-H1401 LAMP ASSY-REAR COMBINATION RH
- 26555-H1401 LAMP ASSY-REAR COMBINATION LH
- 26553-H1400 PACKING LAMP-RH
- 26558-H1400 PACKING LAMP-LH
- 26515-H1000 LAMP ASSY-LICENSE RH
Body
- Hood/Bonnet latch
- 65510-H1000 ROD-HOOD SUPPORT [prop rod]
- 66512-H2500 GROMMET-HOOD SUPPORT ROD
- 65514-H1000 CLAMP-HOOD ROD [rod clip]
- 76486-H1000 Body Sill Retainer [rocker panel trim clip]
- 64803-18000 Canoe Rivet for B10 [holds 620 front wheel well inner splash cover]
- 66919-H1001 CLIP -7708 [for kick panel]
- 73940-H1101 ASSIST STRAP-FRONT [above door]
- 76911-H1101 GARNISH-WINDSHIELD PILLAR RH GRAY -7708
- 76912-H1101 GARNISH-WINDSHIELD PILLAR LH GRAY -7708
- 80940-H1101 ARMREST-FRONT DOOR RH BLACK
- 80940-H1100 620 (BLACK) OPTION to 0678, standard equipment from 0778 USA
- 80940-B9501 620 (BROWN) OPTION to 0678, standard equipment from 0778 USA
- 80940-B9700 620 (BLUE) OPTION to 0678, standard equipment from 0778 USA
- 80504-H1001 REMOTE CONTROL ASSY-DOOR LOCK RH [inside lever & internal rod]
- 80505-H1001 REMOTE CONTROL ASSY-DOOR LOCK LH [inside lever & internal rod]
- 90609-H1400 NUT-OUTSIDE HANDLE ROD [door handle]
- 84371-H1000 HOLDER-OUTSIDE HANDLE
- 80508-H1000 SPRING-RETAINING RH
- 80509-H1000 SPRING-RETAINING LH
- 80690-E6000 CASE ASSY-KEY
- 80600-H1001 CYLINDER ASSY-DOOR LOCK RH
- 80601-H1001 CYLINDER ASSY-DOOR LOCK LH
- 76960-H7400 [B310?] CYLINDER ASSY-GAS FILLER LOCK
- 96315-H1000 BASE-MIRROR OUTSIDE [wing mirror]
- 96327-H6200 [B210] BASE-MIRROR INSIDE
- Inside Mirror (part number differs, but base is the same, so it will bolt on)
- 63845-18000 [B10] CLIP-TUBULAR -7708 [clip for push-in badges]
620 Pickup (Ute)
- 85012-H1000 Rear Bumper RH end
- 85013-H1000 Rear Bumper LH end
- 85206-H1401 rear bumper bracket RH
- 76844-H1201 LOCK ASSY-SIDE WINDOW RH
- 76832-H1201 HINGE-SIDE WINDOW
- 76828-H1200 COVER-SIDE WINDOW HINGE
- 76846-H1201 WASHER [window glass]
- 96905-27800 [B120?] LABEL-LOADING CAPACITY 400KG
