The Datsun 1200 uses a tradition recirculating-ball Steering Gearbox with behind-the axle linkage.
Also see Steering Gearbox
Terminology
- 1. Idler Arm. This bolts to the subframe rail on opposite side from the steering gearbox
- 9. Steering Gear Arm, a.k.a. "Pitman arm"
- 19,20. Side Rod, a.k.a. "tie rod". Left and right hand differ
- 12. Cross Rod, a.k.a. "drag link" or "center link"
- 21, 22, 23, 24. Side Rod Socket Ass'y a.k.a. "tie rod ends". There are four separate parts with left and right-hand threads. Each "socket" has a "ball stud", which is similar to a Ball Joint.
The six ball studs have a Filler Plug on the bottom of each. Replace it with a grease fitting and fill it during each periodic "lube, oil and filter".
Power Steering
Sunny Trucks had optional power steering:
Idler Arm
Idler Arm
- http://www.rockauto.com/catalog/x,carcode,1208483,pgname,Steering
- TRW 18778 through 7/72
Idler Arm Bushing
- 48544-H1000 BUSH-IDLER
- Beck/Arnley 1013851 (2 per idler arm) at http://rockauto.com
Idler Arm Repair Kit (2 bushes, washers & lock nut)
- Raybestos 4501067
- ACDelco 45C1067 or 88911321 $8.41
Cross Rod
The Cross Rod is also known as center link or drag link.
- 48560-H1000 ROD ASS'Y-CROSS JDM B110, B120 (all years)
- 48560-H1600 ASSY-CROSS ROD STEERING USA B110
- ACDelco 45B1035 or 88911087 $99.97
B10
- B10: 48545-18001 BUSHING-idler shaft
- 48560-H6200 ASSY-CROSS ROD LHD USA
- 48560-H2500 ROD ASS'Y-CROSS PB110, PB210
- 48560-H5025 ROD ASS'Y cross steering RHD JDM
B310 (and A10)
- 48560-W5725 ROD ASSY-CROSS,STEERING North America B310, A10
- 48560-W5025 ROD ASSY-CROSS JDM B310, A10
Side Rods
Side Rod also known as Tie Rod, consists of a threaded shaft and two ball-socket "ends".
Side Rod Ends also known as Tie Rod Ends
Side Rod Bar
Aka Tie Rod End Adjusting Sleeve. The flat in the middle is for a wrench to hold it stationary while you thread on the ends. The ends are left- and right-threaded.
- 48512-H1001 BAR-SIDE ROD
- ACDELCO 45A6021 or 88910767
Inner Ends
Inner ends are curved
Inner RIGHT
- 48521-H1001 ASSY-SOCKET SIDE ROD RH INNER
- McQuay-Noriss ES2620X
- Raybestos 4011324
- ACDELCO 45A0324 or 88910158
Inner LEFT
- 48641-H1001 ASSY-SOCKET SIDE ROD LH INNER
- Raybestos 4011327
- ACDELCO 45A0327 or 88910161
Outer Ends
Outer ends are straight.
Outer RIGHT
- 48520-H1001 ASSY-SOCKET SIDE ROD RH OUTER
- TRW ES488L -0772
- Raybestos 4011167
- ACDelco 45A0167 or 88910001 $18.94
Outer LEFT
- 48640-H1001 ASSY-SOCKET SIDE ROD LH OUTER
- TRW ES488R -0772
- Raybestos 4011168
- ACDelco 45A0168 or 88910002 $18.95
