Datsun 1200 B120 pickup came with integral cargo well. This bed/tray is once piece with the body.
Also See
- Tray Liners
- Trayback Utes (flatbed)
Measurements
The Long Body 1200 tray is 295 mm longer than the regular Short Body.
Length Short Bed
- at bottom of tray: 1670 mm
- level with tray top: 1565 mm length
Length Long Bed
- at bottom of tray: 1960 mm
- level with tray top: 1860 mm
Depth:
- 415 mm regular bed
- 420 mm Long bed
Inside Width
- 1285 mm
- Between wheelwells: 980 cm
Bed height from ground
- 795 mm regular bed
- 575 mm long bed
Rope Hooks
The tray hooks are welded on 4 each side. Long body has 5 each side.
The tray "lip" is part of the body inner side panel, not part of the quarter panel (outer side panel).
Removing
Your typical de-hookian operation involves:
Or you can grind the hooks off, but leave the lip:
You can also put new hooks out of site:
Sometimes the Rain Gutter is shaved at the same time:
Sometimes the Tailgate handles are shaved and gate welded into the body:
