Heads may be grouped by engine size, however be aware that the exact same heads were used by various size engines. For example, all A15 engines used heads that were designed for A14 engines.
See Also
- Heads by car model: Cylinder Head Part Numbers
- Head identifying features: Cylinder Head Identification
- Heads by type of head A-series Cylinder Heads
A10
A10 engines were used by the B10 "Datsun 1000" and various Nissan Cherry.
The late B10 head was used by some A12 engines.
180 Type 11041-18002 ASS'Y-HEAD cylinder JDM B10 11041-18001 ASS'Y-HEAD cylinder JDM B10 11041-H0100 ASS'Y-HEAD cylinder JDM B10
H10 Type 11041-H1001 ASS'Y-HEAD cylinder from '70-april JDM B10
B10 Coupe Type 11041-25701 ASS'Y-HEAD cylinder JDM B10 Coupe 11041-25700 ASS'Y-HEAD cylinder JDM B10 Coupe 11041-H0300 ASS'Y-HEAD cylinder JDM B10 Coupe
Nissan Cherry Type 11041-M0100 HEAD ASSY-cylinder A10 E10 11041-M0101 HEAD ASSY-cylinder A10 (from '72-1) E10 11041-M0102 HEAD ASS'Y-cylinder A10 (from '73-3) E10 11041-M0104 HEAD ASSY-CYLINDER EUR N10 0878-0781 11041-M0105 HEAD ASSY-CYLINDER EUR N10 0878-0781
A12
A12A
A12A engines came from B310 USA & N10 JDM.
A12A heads were also used on A14 & A15 engines.
728 Type B310 USA & CAN 11041-H7285 CYLINDER HEAD ASSY 11041-H7284 CYLINDER HEAD ASSY 11041-H7283 CYLINDER HEAD ASSY 11041-H7282 CYLINDER HEAD ASSY 991 Type B310 CAL 11041-H9913 CYLINDER HEAD ASSY A12 CAL 0880- H85 Type N10 JDM 11041-H8500 HEAD ASSY-CYLINDER A12AS 11041-H8501 N10 JDM 11041-H8501 HEAD ASSY-CYLINDER A12AS 11041-H8503 N10 JDM 11041-H8503 HEAD ASSY-CYLINDER A12AS N10 JDM
A13 1974
H62 Type USA B210 1974 11041-H6200 ASSY-HEAD CYLINDER A13 11041-H6201 ASSY-HEAD CYLINDER A13 11041-H6202 ASSY-HEAD CYLINDER A13
A13 1980
For JDM B310 sedans & coupe, the A13S replaced the A12S November 1980. B310 Vans kept using the A12.
11041-H8503 HEAD ASSY-CYLINDER JDM B310 A13S 8011-
A14
A14 heads were also used by A15 models and (some) A12A models. Some A14 heads were used on the A12 from the Datsun 1200 Truck.
G32 Type 11041-G3202 HEAD ASSY-CYLINDER JDM B310,A10,N10 V.A14S 7910-8010 11041-G3203 HEAD ASSY-CYLINDER JDM B310 V.A14S 8011-
H720 Type 11041-H7200 ASSY-HEAD CYLINDER USA B210 -1175 11041-H7201 ASSY-HEAD CYLINDER USA B210 0776-0876
H726 Type 11041-H7261 ASSY-HEAD CYLINDER USA B210 0876-0777
H728 728 Type 11041-H7281 ASSY-HEAD CYLINDER B210 (FED)(GFU) 1276-0578 * also CAN B210 0877-0578 11041-H7282 ASSY-HEAD CYLINDER B210 (FED)(GFU), CAN 0678- * also A14 B310 CAN, FED (KFU) -0778 11041-H7283 ASSY-HEAD CYLINDER B210 (FED)(GFU), CAN * also B310 CAN, FED (KFU) 0878-1078 11041-H7284 CYLINDER HEAD ASSY B310 CAN 1178-0780 * also B310 FED (KFU) 1178-0779 11041-H7285 CYLINDER HEAD ASSY B310 CAN, FED (KFU) 0678-0678
H75 Type -- marked 'H72' on casting? 11041-H7500 HEAD ASSY-CYLINDER JDM B310 A14S V 11041-H7502 HEAD ASSY-CYLINDER JDM A10 A14S.S,K -7803 * also JDM F10 A14S
H77 Type 11041-H7760 ASSY-HEAD CYLINDER USA B210 0877-0578 11041-H7761 ASSY-HEAD CYLINDER USA B210 0678- * also B310 FED (EXC KFU) -0778 11041-H7762 ASSY-HEAD CYLINDER USA B210 * also B310 FED (EXC KFU), N10 FED 0878-0779 11041-H7763 CYLINDER HEAD ASSY B310 FED (EXC KFU)
H786 (786) Type 11041-H7860 HEAD ASSY-CYLINDER JDM B310.V 11041-H7861 HEAD ASSY-CYLINDER JDM B310.V, A10.V N-7806 11041-H7863 HEAD ASSY-CYLINDER JDM B310.V, A10.V, N10.V 7807-7909 11041-H7866 HEAD ASSY-CYLINDER EUR.(-SWE) N10 0880-0781
H87 - FED only 11041-H8700 CYLINDER HEAD ASSY FED 0880-
H89 Type 11041-H8900 HEAD ASSY-CYLINDER JDM B310 S,K.A14S 7811-7903 * also JDM A10 A14S.S,K 7804-7906 11041-H8901 HEAD ASSY-CYLINDER JDM B310 S,K.A14S 7811-7903 11041-H8902 HEAD ASSY-CYLINDER JDM A10.S,K, N10 7907-8003 11041-H8904 HEAD ASSY-CYLINDER JDM B310 S,K.A14S 7904-8010 * also JDM A10 A14S.S,K 8004- * also EUR C120 0681-
H990 (990) Type - FED 11041-H9902 CYLINDER HEAD ASSY FED 0880- 11041-H9901 CYLINDER HEAD ASSY FED 0879-0780
H991 (991) Type - CAL B310 & N10 11041-H9913 CYLINDER HEAD ASSY CAL -0578 11041-H9911 CYLINDER HEAD ASSY CAL 0879-0780 H916 (916) Type - CAL B310 & N10 11041-H9164 CYLINDER HEAD ASSY CAL 0879- 11041-H9163 CYLINDER HEAD ASSY CAL 1178-0779 11041-H9162 CYLINDER HEAD ASSY CAL 0878-1078 11041-H9161 CYLINDER HEAD ASSY CAL -0778
H92 Type - for EGI 11041-H9200 HEAD ASSY-CYLINDER B310,N10 JDM A14E N-7810 11041-H9201 HEAD ASSY-CYLINDER B310 JDM A14E 7811-7903 11041-H9202 HEAD ASSY-CYLINDER B310,N10 JDM A14E 7904-7907 11041-H9204 HEAD ASSY-CYLINDER B310,N10 JDM A14E 7908-8010
H93 Type - for Sweden 11041-H9303 HEAD ASSY-CYLINDER N10 SWE 0880-0781
M24 [dual-spring, otherwise standard A14 type] 11041-M2460 HEAD ASSY-CYLINDER A14T JDM B210 & F10
M49 Type 11041-M4900 B-210 1975-1976 USA B210 & USA F10 1976
A15
All A15 engines used cylinder heads that were designed for A14 engines. In other words, there is no specific "A15" head.
Japan Market
H89 Type - JDM B310 11041-H8904 HEAD ASSY-CYLINDER S,K.A14S 7904-8010, A15S 8011-
H92 Type - EGI JDM B310 11041-H9204 HEAD ASSY-CYLINDER A14E 7908-8010, A15E 8011-
North America Market
H728 (728) Type - B310 CAN 11041-H7285 CYLINDER HEAD ASSY A14 CAN 0678-0678, A15 CAN 0880-
H77 Type - B310 USA FED 11041-H7763 CYLINDER HEAD ASSY A14,A15 FED (EXC KFU) 11041-H7762 CYLINDER HEAD ASSY A14,A15 FED (EXC KFU) 0878-0779 11041-H7761 CYLINDER HEAD ASSY A14,A15 FED (EXC KFU) -0778
H990 (990) Type - B310 USA FED 11041-H9902 CYLINDER HEAD ASSY A14,A15 FED 11041-H9901 CYLINDER HEAD ASSY A12,A14,A15 FED 0879-0780
H991 (991) Type - B310 USA CAL 11041-H9913 CYLINDER HEAD ASSY A14,A15 CAL -0578 11041-H9911 CYLINDER HEAD ASSY A12,A14,A15 CAL 0879-0780
H916 (916) Type - B310 USA CAL 11041-H9164 CYLINDER HEAD ASSY A14,A15 CAL 11041-H9163 CYLINDER HEAD ASSY A14,A15 CAL 1178-0779 11041-H9162 CYLINDER HEAD ASSY A14,A15 CAL 0878-1078 11041-H9161 CYLINDER HEAD ASSY A14,A15 CAL -0778
H95 Type - B310 USA 11041-H9500 CYLINDER HEAD ASSY A15 FED, CAL 0880- * specs appears identical to H87 high-valve head for A14
M66 Type - N10 USA 11041-M6600 CYLINDER HEAD ASSY A15S 0880-0781 * specs appears identical to H87 high-valve head for A14
