Offset
Revision as of 09:26, 6 January 2012; view current revision
The Datsun 1200 stock wheel is 30 mm positive offset (mounting face is 30mm outboard of the wheel's center line). This offset perfectly centers the tire inside the wheel housing. Note that the offset number is not related to wheel width or diameter, but is just the measurement relative to the wheel centerline.
STOCK = 30 mm offset
+30 offset is optimum for Datsun 1200, as the wheel hub face is exactly -30mm offset in the middle of the wheelwell. So a 30 offset wheel will center the tire in the well, allowing the maximum width within stock bodywork.
The offset doesn't mean much without knowing the tire width. All offset will tell you is if the tires will be offset towards the vehicle centerline (+ offset) or away from the vehicle centerline (- offset). But it doesn't say how far the edge of the tire will be -- for that you need to know the tire width along with the offset.
Stock Offset
modelWheel typeOffsetwheel widthTire width
B110steel30 mm (1.18 in)4" wide wheel155 mm
B210/B310steel30 mm (1.18 in)4.5" 155 mm
B210/B310aluminum25 mm (0.98 in)5" wide wheel175 mm
  • Using B210 wheels on B110 results in a 10mm (~1/2 inch) wider overall width (measured from outside-sidewall to outside-sidewall). NOTE: These still fit under unmodifed B110 fenders.
  • B210/B310 Factory Steel vs. Aluminum wheels may have different widths, but have close to the the same overall width as installed. The wheels are 1/2" wider (13mm), but offset on each side is 5mm less. So the outside edges as-installed are less than 2mm further apart from each other than the narrower steel wheels.
Measuring Offset
Wheel Offset is the difference between the flange and the wheel centerline. You don't need to know the width to measure Offset.
  1. Lay wheel flat on the ground (outside face down). You can also do this with tire mounted if it is aired up.
  2. Lay straitedge or straight sawn lumber piece across it, measure to the ground.
  3. Measure down to the flange back face
  4. Subtract the two measurements
offset = (distance to flange) - (1/2 width)
Centerline = 1/2 width
  • Zero Offset: The wheel is centered exactly over the hub face
  • + Offset: The wheel is offset towards the inside of the car
  • - Offset: The wheel is offset towards the outside of the car
Offset Charts
1200 Sedan Wheel hub is offset -30 mm from centerline of the wheelwell. So +30 offset wheels will perfectly centered inside the fender.
A zero-offset wheel will be positioned to the outside of the Sedan as in this photo. Note that the wheel is flush with the body, but has an excess of clearance to the leaf spring.
(a +30 wheel would center the tire)
Optimum offset: +30 for tires up to 175-wide front, 195-wide rear
No Body Mods
REAR SEDAN
Tire size Min. Max. Offset
155/80R12   6   58
165/70R12   7   56
165/55R12  12   52
175/70R13  16   48
185/60R13  21   43
195/60R13  26   38
NOTE:
  • At the min offset, the tire will be very close to the outer bodywork.
  • At the max offset, the tire will be close to the leaf spring.
With Rolled Guards
See Rolling the Guard
REAR SEDAN
205/45R16  23   29
205/60R13  24   27
With 1" Flares
REAR SEDAN
205/55R14   2   25
215/50R14   5   22
225/50R15   8   18
235/45R17  10   17
Choosing Wheel Offset
  • Stock +30 offset works with up to 175-width tires (requiring 5" to 6.5" wide wheels).
  • For wider tires, you must use less wheel offset to move the tire further outboard (away from the spring). But this may foul the bodywork.
Negative Offset
"Deep dish" old-school wheels have lots of negative offset
Positive Offset
FWD wheels typically have lots of positive offset
Datsun 1200 stock wheels have a mild amount of postive offset
1116.gif wheel offset and backspace diagram
Normal Width Tires
The rear wheel mounting face (face of the drum brake) is offset -30mm from the center of the wheelwell. So using a +30mm offset wheel perfectly centers the tire in the wheelwell. Just like the stock wheels (+30 offset). Those clever Datsun engineers!
Narrow Tires
Extra-Wide Tires
Here are some reports by club members indicating what offsets they have made work. Many of these place the wheel face outside of the fenders.
  • Zero offset works well up to 6"-wide wheels.
  • 6.5 and 7" wheels need to be tucked inside a a little more and so require +10 to +15 offset.
  • 8" wheels need to be tucked outside to fit, so require -5 or more negative offset and will stick out past the bodywork.
FWD Wheels
wheel spacers
Offset for Wider Diffs
Wider tires on +55 wheels will cause the tires to hit the leaf springs, but using less offset will push the tire outside.
NOTE: Because the offset is the measure relative to the centerline, and so is Track, the wheel and tire diameter are irrelevant to this diagram. So is the wheel width. The offset only specifies the centering factor.
Wheel & tire width do become important in figuring out if the tire will hit the bodywork or foul on the leaf spring. For tires too wide to fit inside the bodywork, you can either move the leaf springs inboard (difficult) or use a less-offset wheel to push the tire outside the bodywork. Small diameter tires will be OK, but large diameter tires will needs mods to the body such as cutting the opening larger and covering it with an overfender flare.
