All the Nissan Engine Gasket Kits for the Datsun 1200 are NLA, however all individual gaskets are still available for purchase.
See:
Head Set Gasket Kit * Head gasket * Valve Cover gasket * Thermostat gasket * Valve Seals * Manifold Gasket Intake/Exhaust Manifold gasket * EGR gaskets Timing Cover gaskets & Seals Fuel Pump gaskets Oil Pump gaskets Distributor O-ring Crankshaft seals Water pump gasket Oil pan gaskets
ALL NLA
10101-H3927 KIT-GASKET ENGINE A12 0673- 2 10101-H3926 10101-H3926 KIT-GASKET ENGINE A12 0672- 2 10101-H3925 superceded 10101-H3925 KIT-GASKET ENGINE A12 0671- 0 10101-H1025 superceded 10101-H1025 KIT-GASKET ENGINE A12 - 2 10101-18027 superceded 10101-18027 KIT-GASKET ENGINE A12 - superceded 11042-H3927 KIT-GASKET VALVE REGRINED A12 0673- 2 11042-H3926 11042-H3926 KIT-GASKET VALVE REGRINED A12 0672- 2 11042-H3925 superceded 11042-H3925 KIT-GASKET VALVE REGRINED A12 0671- 0 11042-H1025 superceded 11042-H1025 KIT-GASKET VALVE REGRINED A12 - 2 11042-18026 superceded 11042-18026 KIT-GASKET VALVE REGRINED A12 - superceded
