Also see:
Part Numbers Index Main article for usage, photos, cross-reference Rear Axle Tires Wheel
REAR SUSPENSION 1 55020-H1000 ASS'Y-SPRING, rear 2 Sedan, Coupe 2 55020-H1400 ASS'Y-SPRING, rear 2 Van 55020-G1000 SPRING-ASS'Y, rear 2 Truck 3 55203-H1001 MOUNTING-rear suspension, front 2 Sedan, Coupe 55203-H2500 MOUNTING-rear suspension, front 2 Sedan, Coupe (from '73-2) ^ 55203-H1001 4 55219-H1001 PLATE-rear suspension, front upper/inner 2 Sedan, Coupe 55219-H2500 PLATE-rear suspension, front upper/inner 2 Sedan, Coupe (from '73-2) ^ 55219-H1001 5 55044-H1001 BUSHING-rear suspension, front, upper 8 Sedan, Coupe 6 55045-H1000 BUSHING-rear suspension, front 4 Sedan, Coupe 7 08915-23810 WASHER-lock (fixing rear susp., front) 6 Sedan, Coupe 8 89-15238-1 NUT (fixing rear susp., front) 6 Sedan, Coupe -1971 08915-60810 NUT (fixing rear susp., front) 6 Sedan, Coupe 1972- 9 55210-H1400 ASSY-PIN, rear suspension, front 2 Van, Truck 55210-H6600 PIN-ASS'Y, rear suspension, front 2 Van (from '73-2) ^ 55210-H1400 10 55045-H1400 BUSHING-rear suspension, front 4 Van, Truck 11 08911-64010 NUT 2 Van, Truck 12 08915-24010 WASHER-lock 2 Van, Truck 13 81-90812-1 BOLT 4 Van [early] 08190-82010 BOLT 4 Van, Truck 14 08915-23810 WASHER-lock 4 VAN 15 55220-H1000 ASS'Y-shackle, rear suspension, rear 2 16 55221-H1000 PLATE-shackle, rear suspension, outer 2 17 55046-H1000 BUSHING-shackle, rear suspension, upper 4 18 55047-H1000 BUSHING-shackle, rear suspension, lower 4 19 08915-23810 WASHER-lock (fixing rear suspension front) 4 20 08911-60810 NUT (fixing rear suspension front) 4 21 55266-G1000 SEAT-rear suspension, lower (L.H.) Truck 55262-H1001 SEAT-rear suspension, lower 2 Sedan 55262-H2801 SEAT-rear suspension, lower 2 Sedan (from '73-5) <x> 55262-H1001 55262-H1401 SEAT-rear suspension, lower (R.H.) Van 55262-H1402 SEAT-rear suspension, lower (R.H.) Van (from '73-6) <x> 55262-H1401 22 55266-G1000 SEAT-rear suspension, lower (L.H.) Truck 55266-H1401 SEAT-rear suspension, lower (L.H.) Van 55266-H1402 SEAT-rear suspension, lower (L.H.) Van (from '73-6) <x> 55266-H1401 55262-H1801 SEAT-rear suspension, lower (R.H.) Coupe 55262-H1802 SEAT-rear suspension, lower (R.H.) Coupe (from '73-5) <x> 55262-H1801 55266-H1801 SEAT-rear suspension, lower (L.H.) Coupe 55266-H1802 SEAT-rear suspension, lower (L.H.) Coupe (from '73-5) <x> 55266-H1801 23 55247-G1000 CLIP-rear spring 4 Truck 55247-H1001 CLIP-rear spring 4 Sedan, Coupe 55247-H1002 CLIP-rear spring 4 Sedan, Coupe (from '73-5) <x> 55247-H1001 24 55247-H1401 CLIP-rear spring 4 Van 55247-H1402 CLIP-rear spring 4 Van (from '73-6) <x> 55247-H1401 25 55248-H1000 PLATE-clip, rear spring 2 Sedan 55248-H1000 PLATE-clip, rear spring 2 Sedan (from '73-5) <x> 55248-H1000 27 55240-H2500 BUMPER-ASS'Y, rear axle 2 Truck 55240-H1400 ASS'Y-BUMPER, rear axle 2 Van, Coupe 55240-H1800 ASS'Y-BUMPER, rear axle 2 Van, Coupe (from '73-5) <x> 55240-H1400 28 08911-64010 NUT 8 29 08915-14010 WASHER-lock 8 30 55350-H1000 TORQUE-arrester, rear suspension Sedan, Coupe 31 08915-23610 WASHER-lock (fixing torque arrester) 2 Sedan, Coupe 32 81-10616-1 BOLT (fixing torque arrester) 2 Sedan, Coupe 08910-61601 BOLT (fixing torque arrester) 2 Sedan, Coupe 08910-61625 BOLT-fix head with washer 2 Sedan, Coupe <> 08910-61601
1 43010-H1004 COMP-CASE REAR AXLE SEDAN 0673- 5 43010-H1003 1 43010-H1404 COMP-CASE REAR AXLE COUPE 0673- 5 43010-H1803 1 43010-H1802 COMP-CASE REAR AXLE COUPE -1172 2 1 43010-H1003 COMP-CASE REAR AXLE SEDAN 1272-0573 32 43010-H1002 1 43010-H1002 COMP-CASE REAR AXLE SEDAN -1172 2 1 43010-H1803 COMP-CASE REAR AXLE COUPE 1272-0573 32 43010-H1802 2 43067-H0100 STUD-GEAR CARRIER FIX (8) 8 3 43059-A1600 PLUG-TAPER SQUARE SOCKET 4 32103-14600 ASSY-PLUG DRAIN 5 38322-55100 ASSY-BREATHER 6 38162-G0300 ASSY-SHAFT REAR AXLE (2) 2 7 40222-18000 BOLT-HUB ROAD WHEEL (8) 8 8 43065-10600 CLIP-BRAKE TUBE (2) 2 9 43066-22500 SEAT-CONNECTOR BRAKE HOSE 10 43070-04101 SPACER-REAR AXLE BEARING (2) 2 -1172 2 10 43070-H5000 SPACER-REAR AXLE BEARING (2) 2 1272- 2 43070-04101 11 43215-18000 BEARING-REAR AXLE (2) 2 SEDAN COUPE 11 43215-H5000 BEARING-REAR AXLE (2) 2 SEDAN COUPE 0673-1172 25 43215-18000 12 43255-18000 COLLAR-REAR AXLE BEARING (2) 2 12 43255-H1000 COLLAR-REAR AXLE BEARING (2) 2 1271- 2 43255-18000 13 43036-H5000 SHIM-REAR AXLE CASE END (0) 0 SEDAN COUPE 0673-1172 25 43036-10601 13 43036-10601 SHIM-REAR AXLE CASE END (0) 0 SEDAN COUPE 14 43239-04100 PACKING-GREASE CATCHER (2) 2 -1172 2 14 43239-H5000 PACKING-GREASE CATCHER (2) 2 1272- 2 43239-04100 15 43237-18000 CATCHER-GREASE RH -1172 2 16 43236-H5000 CATCHER-GREASE (2) 2 1272- 2 43236-18000 16 43236-18000 CATCHER-GREASE LH -1172 2 17 43252-18000 SEAL-OIL REAR AXLE SHAFT (2) 2 17 43252-H1000 SEAL-OIL REAR AXLE SHAFT (2) 2 0372- 2 43252-18000 17 43252-H1010 SEAL-OIL REAR AXLE SHAFT (2) 2 0372- 43252-H1000 18 08915-23810 WASHER-SPRING LOCK (8) 8 19 43063-18001 BOLT-FIX REAR BRAKE DISC (8) 8 20 08912-43810 NUT-HEX SELF LOCK (8) 8 21 43206-18000 DRUM-BRAKE (2) 2 22 40300-H1001 ASSY-ROAD WHEEL 4JX12 (3) 3 DELUXE 23 40310-H1772 SET-TIRE & TUBE 6.00-12-4PR WITHE FMVSS (3) 3 OP 23 40310-H1940 SET-TIRE & TUBE 155SR12 RADIAL FMVSS (3) 3 OP 23 40312-H1922 TIRE 6.00-12-4PR FMVSS (3) 3 23 40310-H1928 TIRE 6.00-12-4PR SNOW FMVSS (3) 3 OP 24 40315-H1100 COVER-ROAD WHEEL (2) 2 DELUXE (OP STD) 25 40315-H1800 COVER-ROAD WHEEL (2) 2 OP COUPE 25 40315-H1801 COVER-ROAD WHEEL (MEXICO MADE) (2) 2 COUPE 0872- 5 40315-H1800 26 40225-27700 NUT-ROAD WHEEL 1 (16) 16 27 40324-H1000 WEIGHT 40G WHEEL BALANCE (0) 0 2 40324-18000 27 40329-18000 WEIGHT 90G WHEEL BALANCE (NOT ADOPTED (0) 0 27 40328-18000 WEIGHT 80G WHEEL BALANCE (NOT ADOPTED (0) 0 27 40327-H1000 WEIGHT 70G WHEEL BALANCE (0) 0 2 40327-18000 27 40327-18000 WEIGHT 70G WHEEL BALANCE (0) 0 27 40326-H1000 WEIGHT 60G WHEEL BALANCE (0) 0 2 40326-18000 27 40326-18000 WEIGHT 60G WHEEL BALANCE (0) 0 27 40330-18000 WEIGHT 100G WHEEL BALANCE (NOT ADOPTED (0) 0 27 40324-18000 WEIGHT 40G WHEEL BALANCE (0) 0 27 40323-H1000 WEIGHT 30G WHEEL BALANCE (0) 0 2 40323-18000 27 40323-18000 WEIGHT 30G WHEEL BALANCE (0) 0 27 40322-H1000 WEIGHT 20G WHEEL BALANCE (0) 0 2 40322-18000 27 40322-18000 WEIGHT 20G WHEEL BALANCE (0) 0 27 40321-H1000 WEIGHT 10G WHEEL BALANCE (0) 0 2 40321-18000 27 40321-18000 WEIGHT 10G WHEEL BALANCE (0) 0 27 40325-H1000 WEIGHT 50G WHEEL BALANCE (0) 0 2 40326-18000 27 40325-18000 WEIGHT 50G WHEEL BALANCE (0) 0 28 40360-H1000 CHAIN-TIRE (4) 4 OP COUPE
