CA200
Revision as of 07:07, 4 November 2012; view current revision
CA200 is Nissan straight axle fitted with R200 type gearset. It is the only (?) Nissan live axle with Salisbury/GM type differential, meaning the gear carrier built into the axle (has a non-removable center section).
GASKET-GEAR CARRIER
38353-Y0801
38353-Y0800
R31 w/28-spline axles (easily confused with BW diff)
Similar
For comparison
GM salisbury-type 10-bolt out of Holden Commodore VN
R31
JAPAN
R31 Wagon with RB20T SOHC Turbo 1986-1990 4.11 (build dates 8601-9005)
C22
GC22 JPN Vanette
 CA200 8611- some 4WD
 * OP. LSD
 * LSD use 38423-C6000 side gears
