Clock
Revision as of 09:09, 27 July 2015; view current revision
Factory clocks were optional in all 1200 models for either rectangular or round style dashes. It was standard equipment on GL & GX models where the clock was fitted the Console, while other models fitted the clock in the instrument panel to the left of the speedometer.
Clocks were made by Niles, Kanto Seiki (関東精機), Citizen or Jeco (Denso).
Rectangle
Rectangular, genuine Niles clock for STD or DX model. This one is for later B120 pickup.
Original
Green Line original style
Jeco (ジィコー) original style - Narrow Font
Theoretical LHD face
Updated
newer style - Wide Font. No green lines.
21253.jpg Citizen clock
Option
2210.jpg Options
Font
As with the other gauges (Speedometer, Tachometer) later versions use a different font:
Facelift
1972 Facelift
  • Extra bracket for dash fitting
  • Wider Font and no green lines
  • Anti-glare cover (cone-shaped)
JECO
Success stamped K.S. Clock
PB110
PB110 Sunny Excellent
Dash Fitting
The clock bolts into the dash by using the tabs along the face. Unbolt the mask and bolt in the clock.
click
The tabs further back on the body are used for mounting in the floor console.
Console
Clock was fitted to the OPTION large console.
See main article: Console for more details
The clock is powered by a constant-Hot wire. If you wire to IGN, it only runs when the key is on :-)
  1. 12V Power: L or RB
  2. Ground/Earth: B
  3. Lamp: RB or RG
Clock: Blue or Red/Black wire
Power feed 12V (Blue) hanging down from the harness.
Clock: Red/Blue or Red/Green
Lamp feed on instrument panel
Clock: Black wire
Ground/Earth point on instrument panel
(panel frame on rectangular panel)
Service Bulletin
Rectangle
Australia
'D' Mask for clock
JAPAN kaku メーター 角
'S' Mask for clock
25005-H1000 MASK-clock 3 speed, VDT
25006-H1000 NUT-fix clock & tachometer (3)
27390-H1000 ASS'Y-CLOCK (op.) 3 speed, VDT, B120 -7511
27390-G1000 CLOCK ASSY 7512-7803
Round
JAPAN maru メーター 丸
25005-H1800 MASK-tachometer ['Sunny' for clock delete]
27380-H2000 ASS'Y-CLOCK GL,GX
27390-G1660 CLOCK ASSY 7804-
 08540-51612 SCREW
 08964-10510 NUT
JAPAN 1972
27380-H3300 CLOCK ASS'Y GL, (op.) Std, DX [Long-bracket type for use with 1972 Dash]
25017-H3100 CLAMP-front cover (3)
25012-H3300 COVER ASS'Y-front (for clock) GL, (op.) Std, DX
 [dash blind] has long bracket on top
25012-H3100 COVER ASS'Y-front ['Datsun' for clock delete]
fixing clock & tachometer
 08964-10510 NUT
 08510-51612 SCREW
 08915-43510 WASHER-plain
27380-H3400 CLOCK ASS'Y (for console box) GX
 08513-41212 SCREW (3) GX
 08915-43410 WASHER-plain GX
74990-H2021 MASK-clock CG,GX [console]
27380-H2000 ASSY-CLOCK USA
27389-H2300 SPACER FIXING CLOCK TO CONCOLE BOX
25005-H1810 MASK-TACHOMETER "DATSUN" [delete plate for dash]
25005-H1800 MASK-TACHOMETER ['Sunny' delete blank]
27380-H2600 CLOCK ASS'Y GL, GX, (op.) DX
時計 クロック
