RHD 1200 used a clutch cable while LHD versions used a Hydraulic clutch linkage.
Both cables are the same length (800mm), they are identicle except for the aluminium end that slips into the gearbox. The larger of the two cables is 25mm and the other is about 18mm. You can also fit a washer if using the small cable in a large-hole transmission.
Adjustment
1. On transmission: adjust for 3-4 mm play
2. Inside: adjust pad height (139.5-143.5 mm from floor).
3. Finally, check pedal free play (11-15mm)
NOTE: it must have free play to avoid burning out the clutch check with fingertip pressure.
Details are in the Datsun 1200 Factory Service Manual or any Repair manual (Gregory's, etc).
Removal
1. Loosen the locknut, then unthread the nut. These are the two 17mm nuts on the clutch cable at the firewall.
2. Pull the cable end off the Clutch Fork Arm
For OEM numbers, see Clutch Pedal Part Numbers
18mm - B110 & ute up to August 1973 30670-H1000 early 30670-H1001 CABLE ASS'Y-clutch operating B110 * small clutch cable hole in transmission [83 cm length]![]()
B120 1973 up (25 mm) 30670-G1000 7309- 30670-G1600 7510-8304 30670-G1601 8305-8910 [77 cm?] 30670-G1500 8910- [81 cm?]
1-inch (25mm) clutch cable hole in transmission - B210 30670-H5001 CABLE ASS'Y-clutch operating B210 all * EXCEPT: 63-series transmission JDM used hydraulic clutch Quinton Hazel QCC.1076![]()
30670-H8500 -7909 B310 [bracket, no nut] 30670-H8510 7909- B310, 8110- Van 30670-H9100 BC2052
Length 30670-H1001 750 mm or 830 mm 30670-H5001 30670-H8500 30670-H8510 770 mm 30670-H9100
1982-1986 Stanza CA20 * 40.25 inches BECK/ARNLEY 0930558 ATP Y348 #30670D2801 DORMAN 14850 {TECHoice}
1983 Sentra E15 * 29.5 inches BECK/ARNLEY 0930556 ATP Y327 {#3067004A00} DORMAN 14849 {TECHoice}
クラッチ ケーブル
