Nissan R32 used ribbed, Light Alloy 4-piston brake calipers.
R32 GT-R 16" wheel Sumitomo make
R32 GT-R WITH 17" WHEEL
200B/Stanza/240K strut R33 disc R32 caliper
R32 disk and calipers on 1200 strut
Rotors
R32 4-lug rotor (also used by S13) 280 mm 40206-55F01 9108- RB25 including GTS 2.5 257 mm 40206-71E06 8905- RB20 including GTS, GTE 251 mm 40206-40F01 8905- CA18I GXi 40206-40F02
R32 5-lug rotor 280x30 mm 40206-40P02 9108- HI.RB20DET > 40206-04U01,40206-04U03 * also USA Z32 280x20 mm 40206-88E01 8905- HI.2WD.RB20DT.GTST <> 40206-88E04 * also J30 (USA+JAPAN) 280x32 40206-05U00 8908- RB26DETT & GTR 40206-05U01/40206-05U06/40206-05U07 * 40206-05U10/40206-05U11/40206-05U12/40206-05U13 40206-12U00 9302 GT-R.17.MT.FT 40206-12U01 * also AWC34.RB326DETT
40206-40P02 280 x 30 Height: 53.6 mm Diameter: 280.2 mm Centering Diameter: 68.1 mm Pitch Circle Diameter: 114.3 mm Brake Disc Thickness: 30 mm
40206-88E01 280 x 22 mm Height: 49 mm Diameter: 280 mm Centering Diameter: 68 mm Pitch Circle Diameter: 114.3 mm Brake Disc Thickness: 22 mm
296 x 32 mm 40206-05U12 RH, 40206-05U13 LH cross-drilled
Calipers
R32 Single-piston * 41001-40F01 CA18I * 41001-73L01 RB20DT.GTS-T, RB25DE * 41001-44F01 RB20E, RB20D
R32 4-piston ribbed * 41001-04U00 RB20DT.TYPE-M,RB20DT.HI.4WD 41001-04U01 * 41001-05U00 GT-R & RB26DETT 41001-05U01 * 41001-45P00 RB20DT.HI.4WD 41001-40P00 40mm bore also Z32 USA
R32 4-piston non-ribbed (iron) * 41001-12U00 GTR.17 41001-24U00
R34
R34 CALIPER Single-piston * 41001-AA000 RB20DE Twin-piston sliding * 41001-AA100 OPTION RB20DE F/DWHL6 * 41001-0V100 IRS.4WD.RB25DE Four-piston ribbed * 41001-AA510 OPTION IRS.2WD.RB25DE F/DWHLE RB25DET Four-piston non-ribbed * 41001-AA300 RB26DETT
Z32
Z32 is Nissan 300ZX 1989-1996
- Japan: 1989-1990
- USA: 1990-1996
Z32 USA ROTORS 20206-40P02 <> 40206-04U00 * VG30DTT -0491 * VG30E 0790-0491 40206-04U03 <> 40206-69F00 * 0491-VG30DTT + VG30D 40206-30P01 * VG30D -0390 40206-30P03 <> 40206-30P05 * VG30D 0390-0790
Z32 USA 1990-1996 (all 4-piston) 280 x 26mm rotor * 41001-30P00 CALIPER alloy 1990 * 41001-04P00 CALIPER alloy 280 x 30mm rotor * 41001-37P00 CALIPER alloy 1990-1992 * 41001-37P01 CALIPER iron 1993-1996 40mm bore x4 non-ribbed
Centric 141.42072 FL, 141.42071 RH, to June 1990full
Centric 141.42074 FL, 141.42073 RH, from July 1990full
Centric 141.42078 FL, 14.1420177 FR IRONRockAutofull
Pigdog
296mm disc rotor
GTST/Z32 calipers on 296 x 30 rotors on 810 struts
