Also see: Part Numbers Index Main article for usage, photos, cross-reference Heater Ventilation Knobs
NOTE: Individual heater parts are not listed
ROOM HEATER 27010-H1000 HEATER KIT-room DX,GL,GX 27010-G1000 HEATER KIT-room Truck DX, (op.) TRUCK STD <> 27010-G1001 27010-G1001 HEATER KIT-room Truck DX, (op.) TRUCK STD 27010-G1002 HEATER KIT-room Truck DX, (op.) TRUCK STD (from '72-10) > 27010-G1001
Late Sunny Truck
1975-1994
HEATING UNIT ASSY-FRONT
27011-G1001 7510-7803 NICHIRA <0,0> 27011-G1060
27011-G1060 7804-8910 NICHIRA
27100-95W00 8910-
27015 CASE ASSY-FRONT HEATER
27016-G1000 7510-7803 BLACK NICHIRA
27016-G1060 7804-8910 BROWN NICHIRA
27124-95W00 8910-
27025 27022-H1000 HOSE-WATER
27070 27014-G1000 MOTOR & FAN ASSY-BLOWER NICHIRA
27077 27015-H3100 RESISTANCE-ELECTRIC NICHIRA
27115 27013-H1001 CORE ASSY-FRONT HEATER NICHIRA
27117 27017-B8520 COCK ASSY-FRONT HEATER
74148M 27017-G1000 KNOB-CONTROL NICHIRA B421
27610 27610-H7900 COOLING UNIT ASSY 7804- DKKC B421
27616 BRACKET-COOLING UNIT, NO 2
27616-G1660 7804-8109 DKKC
27616-G1900 8110- DKKC
27618 BRACKET-COOLING UNIT, NO 4
27618-G1660 7804-8109 DKKC
27618-G1900 8110- DKKC
Standard Type
1 27010-H1600 KIT-ROOM HEATER OP 27013-H1001 ASSY-CORE HEATER OP 27013-H1000 2 27013-H1000 ASSY-CORE HEATER OP 3 27014-H1000 ASSY-MOTOR HEATER OP 4 27015-H3100 ASSY-RESISTANCE WITH FUSE OP 0272- 5 27135-H1600 COMP-CONTROL HEATER OP 6 27137-H1000 KNOB-HEATER CONTROL'A' OP 7 27138-H1000 KNOB-HEATER CONTROL'B' OP 8 08310-30612 SCREW 2 OP 9 08915-13310 WASHER 2 OP 10 27139-H1600 ASSY-CABLE HEATER CONTROL'A' OP 11 27140-H1600 ASSY-CABLE HEATER CONTROL'B' OP 12 27141-H1600 ROD-HEATER CONTROL OP 13 27142-H1000 PIN-CONTROL ROD OP 14 27143-H1000 WASHER CONTROL ROD OP 15 08915-13510 WASHER 2 OP 16 08410-51212 SCREW 2 OP 17 08310-61014 SCREW 2 OP 0570- 18 27018-H1000 VALVE-ROOM HEATER 2 OP 19 27161-H1000 HOSE-DEFROSTER 2 OP -972 2 19 27161-H1001 HOSE-DEFROSTER 2 OP 1072- 2 27161-H1000 20 27171-H1000 NOZZLE-DEFROSTER 2 OP -972 2 20 27171-H1001 NOZZLE-DEFROSTER 2 OP 1072- 6 27171-H1000 21 08513-51212 SCREW 4 OP 22 08915-43510 WASHER 4 OP 23 08964-10510 NUT-SPRING 4 OP 24 27020-H1000 HOSE-WATER OP 24 27020-G1900 HOSE-WATER OP 27020-H1000 25 27021-H1000 HOSE-WATER OP 25 B7021-H1002 HOSE-WATER OP 27021-H1000 26 08723-12000 CLAMP-HOSE 5 OP 27 27051-E0100 CLIP-WATER OP 28 08723-13600 CLAMP-HOSE 2 OP 29 27070-H1000 CONNECTOR-WATER INLET OP 30 27075-H1000 CONNECTOR-WATER OUTLET OP 31 27078-B2000 CLIP 2 DELUXE(OP STD) 0570- 32 08510-51012 SCREW-TAPPING 2 DELUXE(OP STD) 0570- 33 08915-43510 WASHER-PLAIN 2 DELUXE(OP STD) 0570- 34 27363-18001 GROMMET-HEATER 2 OP 2 27363-18200 34 27363-18200 GROMMET-HEATER 2 OP 35 08915-53610 WASHER-PLAIN 4 OP 36 08915-13610 WASHER-SPRING 4 OP 37 08460-61612 SCREW 4 OP 38 27012-H1000 PLATE-AIR INTAKE FOR HEATER LESS OP 39 08915-53610 WASHER-PLAIN PLATE FIX 4 STD 40 08915-13610 WASHER-SPRING 4 41 X2160-30231 KNOB-VENTIRATOR OP 42 X2160-30213 ASSY-PANEL HEATER BOX OP 43 X2160-30600 ASSY-VALVE WATER CONTROL OP 43 X2161-30600 ASSY-VALVE WATER CONTROL OP 2 X2160-30600 43 B7017-B8500 ASSY-VALVE WATER CONTROL OP X2161-30600 44 X2160-30503 HOSE-HEATR OP 44 27022-H1000 HOSE-HEATR OP X2160-30503
Air Ventilator
1 66502-H1000 ASSY-PLATE, AIR VENTILATOR 2 66511-H1000 ASSY-LID, AIR VENTILATOR 3 66504-18001 SPRING-AIR VENTILATOR R.H. 4 66505-18001 SPRING-AIR VENTILATOR L.H. 5 66507-18000 PIN-AIR VENTILATOR 6 66520-H1000 ASSY-CONTROL, AIR VENTILATOR 7 27137-H1000 KNOB-HEATER CONTROL 8 84371-78200 HOLDER-ROD 2 9 08915-53610 WASHER-PLAIN 2 10 08915-13610 WASHER-LOCK 2 11 08460-61612 SCREW M6 2 12 08310-51214 SCREW M5 2 13 66522-H1600 ROD-CONTROL, VENTILATOR
