Nissan wheels
Revision as of 19:12, 27 June 2018; view current revision
Category: Wheel And Tire
<-- Back to Wheels (includes 1200 & Sunny wheels)
R30 Rims
15 X 6 Skyline#R30 wheels, 20-spoke hurricane-type. #R31 Skyline was 24-spoke
4020.jpgAlbum 4020 400px-1984_Nissan_Skyline_%28R30%29_Ti_Special_Edition_2.4E_hatchback_%2825977751876%29.jpgWIKI go to Wikipedia 13358.jpgAlbum 13358 5514.jpgAlbum 5514 5162.jpgAlbum 5162 8236.jpgAlbum 8236 10535.jpgAlbum 10535 3196.jpgAlbum 3196 3194.jpgAlbum 3194 10308_4f7d6ccfd7cee.jpgPost 403014 17004.jpgAlbum 17004
R31 Skyline
See Main Article: R31 Wheels
th_R31-silhoutte.jpg th_R31_Silhouette.jpg th_Gts1-wheel.jpg th_425px-Gts2-wheel.jpg th_40300-J7111.jpg th_15x630_R31.jpg
R31 Skyline spare steel wheels
"Pursuit/chaser" style wheel may be used on Datsun 1200.
See Main Article: Pursuits
R32 Skyline
5-lug
8" wide, fit with PCD adapters?
11543.jpgAlbum 11543 400px-Nissan_Skyline_R32_GT-R_001.jpgWIKI go to Wikipedia 13493.jpgAlbum 13493
R32 GTS wheels 16 x 6.5 with 205/40R16
20878.jpgAlbum 20878
Stanza SSS
Australian-assembled 1981-1983 Stanza SSS (PA10MX) has 13" alloy rims. Looks like Bridgestone#Zona Special Antares.
SSS wheels reportedly not fit 1200 without spacers.
11098_4e229c93e2f27.jpgUpload click to view 174_5a505db957ab7.jpgPost 487146 12575.jpgAlbum 12575 13632.jpgAlbum 13632 7642.jpgAlbum 7642 552.gifAlbum 552 10421.jpgAlbum 10421 25129.jpgAlbum 25129 25128.jpgAlbum 25128
C22
USA C22
40300-V6104 5.5-JJX14 +40 <> 40300-V6120
40300-V8000 SPARE <> 40300-V8077 [8-hole steel]
40300-17C25 AL [turbine]
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
810
Datsun 810 200B/180B/Bluebird
rose-petal wheel
1274.jpgAlbum 1274
C-type 13" (also used by S10) & E-type 14"
23743.jpgAlbum 23743
A-type 5.5x14
40300-R4625 with nut set KOHBE <> 40300-U9625
40300-R4626 with locking nut set KOHBE <> 40300-U9626
40300-R4671 40300-U8925 A-type 14" (export option)
A-type
Datsun 810 factory OPTION B & OPTION C wheels: 13" x 5"
23907.jpgAlbum 23907
B-type 6-spoke
40300-U7527 B-type 5Jx13
40300-U7528 B-type 5Jx13 locking
C-type 8-slot
40300-W6027 C-type 5Jx13
40300-W6028 C-type 5Jx13 locking
B-type
Australia 200B Aspen GL (optional GX) 14x6 (20-spoke)
2473.jpgAlbum 2473 951.jpgAlbum 951
E-type 32-spoke SSS, LN 5.5JJx14
40300-S0625 with nuts
40300-S0626 locking nut
200B SX (32-spoke) 14x6
3542.jpgAlbum 3542 1438.jpgAlbum 1438 3627.jpgAlbum 3627 25700.jpgAlbum 25700 3143_49cf5554603f5.jpgPost 248862
910
AUS/JAP Bluebird
14" steel 8-slot/8-square hole
7097.jpgAlbum 7097
USA 910 "Datsun 810" and "Maxima"
40300-N8810
40300-N8870 <1>  40300-N8804
40300-W1000
40300-W1004 <5>  40300-W1014
40300-W1070 <5>  40300-W1004
40300-W2426
40300-W2428
40300-W2426
U11
1985-1988 U11 Maxima used 15x6 +40 wheels -- same dimensions as #S13 wheels. They use the Datsun bolt pattern 4-on-4.5" (114.3mm). Can be used on 1200s by utilizing wheel spacers. 1987-1988 came with 15x6+40 wheels in 4-lug and 5-lug versions.
16-slot turbo/aero wheels
nissan-maxima-wheels-62271-b.jpg 400px-1987_Nissan_Maxima_rear.jpgWIKI go to Wikipedia
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
See Main Article: TRX_Wheels
Pulsar
Nissan Pulsar/Cherry/Langley, FWD small car.
N12
Pulsar N12 4.5x13 FC/FL/SSS/GF (Prince Liberta Villa, sold by Nissan Bluebird Shop)
?40315-01M20 WHEEL DISC ORNAMENT
22948.jpgAlbum 22948 22949.jpgAlbum 22949
Pulsar N12 5Jx13 Alumi
40300-01M25/40300-01M26/40300-01M28/40300-01M85/40300-01M86/40300-01M88
40300-01M70/40300-01M76
13x5
20200.jpgAlbum 20200
N12 ET
The Pulsar ET was the sedan/multiback version of the N12 Turbo, and came with the legendary E15ET engine. (The coupe version was the EXA, or NX in USA)
3170.jpgAlbum 3170
651.jpgAlbum 651
Pulsar ET Turbo - 14 x 5.5
174_56ef99aaecb10.jpgPost 477480 3786.jpgAlbum click to view
EXA
The EXA was the coupe/sporty version of the Pulsar Turbo, and the N13 EXA came with the legendary CA16DE or CA18DE engine. Badged "Pulsar NX" in USA (SE with CA, XE with E15/G16).
EXA wheels N12 or N13 ???
3575.jpgAlbum 3575
Similar
4517.jpgAlbum 4517
For 24-spoke, see Cheviot Classic 13x5.5
F31
Nissan F31 was badged "Nissan Leopard" or "Infiniti M30".
8-hole aero fan
buy at rtw wheels
buy at wheel collision
1990-1992 Infiniti M30
slanted 8 slot
15 x 6.5 +25
4 on 4-1/2 bolt circle
Pilot hole diameter 66 mm
23 lbs
left & right wheels
F31 Japan
8602-8808
 14x5.5+30 7-slot styled steel
   40300-58L05 8602-8702 VG20 [F31,C32]
   40300-58L07 8702-8808 VG20 [F31,C32]
 15x6+30 10-slot styled steel
   40300-59S00 8602-8702 V20T.XS [F31,C32,R31]
   40300-59S07 8702-8808 V20T.XS GOLD [F31,C32,R31]
               8808-9805 VG20E *(VG20DT+VG30#)
   40300-59S08 8905- VG20E *(VG20DT+VG30#) CHROME [F31]
8602-8808 spare steel 4x15 4-slot
  VG20 40300-03E00 8602-8808 <> 40300-28E15 <7> 40300-16E15
  VG30.ULTIMA 40300-59S15 8602-8808
  ALL 40300-59S15 8808-
8602-8603- alloy 8-slant/spoke 6.5x15
  40300-F6226 RH 8808- <> 40300-F6228 GOLD VG20DT+VG30# *VG20E
  40300-F6626 RH 8808- <> 40300-F6628 SILVER VG20DT+VG30# *VG20E
  40300-F6627 LH <> 40300-F6225
  40300-F6526 8602-8808 <> 40300-F6528 VG20T.XS2+VG30D.ULTIMA *(*VG20E.XJ#+*VG20T.XS)
  40300-F6527 LH
Spare Tire
15x4T+40
40300-28E15 キイロ 4ケシ 60ネン キネンシヤ <> 40300-03E00 <7> 40300-16E15
* C23 Vanette
* M10/M11 Prairie
* S12/S13/RS13 Silvia
* W10 Avenir
* T12/T12Y Violet/Stanza/Bluebird
* A31 Cefiro
* F31 Leopard
* R31/R32 Skyline
* C32/C33 Laurel
* P10/P10E Primera
* U11/U12/U13 Bluebird
40300-28E15
174_574a4b609f2cc.jpgUpload click to view
40300-16E15 15x4T BLACK steel クロ <7> 40300-28E15
* B15
* C23
* K30S
* P11/P11E
* R33
* RS13/S14
* U14
* W10/WP11
* C34
* U13
S110
S110 1980-1983 Nissan Silvia Datsun 200SX/180SX/240RS
40300-N8810 4TX16 SPARE
40300-N8900 5JX14 0179-0783
40300-N8910 5JX14 0781-1081
40300-N8427 5.5JJX14 AL [16-spoke]
40300-N8825 5.5JJX14 AL <4> 40300-11S25 [16-spoke 5.5x14 +25]
40300-S6027 5.5JJX14 AL <4> 40300-N8427 [32-spoke 5.5JJ14 25]
40300-S6027 32-spoke hurricane
S13
?40300-15U28 15X6JJ silver Hitachi [K504]
* RS13 Type-X 9505- option
* R33 some
* S14 option K.2WS.QS
8233.jpgAlbum 8233
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole
* Base: 195/60R15
* SE: 205/60R15
10-hole Spare
15" x 4", 4 Lug, 4.5" Bolt Pattern
https://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/th_nissan-240sx-wheels-62253.jpg
40300-50F26 silver top 15x6JJ+40 7-star
* RS13 (S13 Hatchback/180SX)
* A31 aero type silver
* C33
* R32 including V Selection 2 and 60th Anniversary
9360.jpgAlbum click to view 9361.jpgAlbum click to view
9333.jpgAlbum 9333 9362.jpgAlbum 9362
Z-car Rims
Datsun S30  "Fairlady Z" or 240Z/260Z/280Z
Datsun S130 "Fairlady Z" or 280ZX
See Main Article: Z_Rims
th_280zxt.jpg th_40300-P8185.jpg th_40300-N3200.jpg th_40300-03P25.jpg th_62172used.jpg th_62143goldto.jpg
