Datsun 1200 uses a traditional pellet-type engine cooling thermostat. It regulates temperature by closing when cold to keep hot water in the engine, and opening when hot allowing the coolant to flow to the Radiator.
Cooling Thermostat
Replacement
Replacement of the thermostat is called for when:
- the engine runs too hot and other causes have been ruled out. See Cooling System Diagnoses
- the engine runs too cold
- Put a bucket under the radiator fan to catch spilled coolant
- Loosen the clamp on the hose at the water outlet
- Twist and pull the hose off the outlet
- Remove the two fastening bolts
- Scrape all traces of gasket off water outlet and cylinder head face
- be careful not to nick the aluminum of the gasket faces
- Fit thermostat into engine, then gasket, then housing and tighten moderately
- The gasket goes against the housing (not the head).
- Top up coolant
- Rinse spilled coolant off engine and body with water
- After engine has been fully warmed up, and cooled down, top up coolant again.
Be sure to fit thermostat with spring facing into engine
WARNING: Due to air pockets, the coolant level usually drops down and the engine can easily overheat if not monitored for a few days after changing the thermostat.
Temperature
It is not unusual with any 10-year old stock radiator for the temperature to rise during summer. If this occurs with your Datsun, don't panic. The engine can run all day close to the "H" mark.
DO NOT let it go onto the H mark. Pull over immediately if it goes past the H mark. Don't wait 30 seconds, it could be too late.
Typical Temperature
If this worries you, fit a slightly larger radiator to provide more cooling than Datsun provided with the 1200s.
According to Owner's Manual: Water Temperature Gauge,
the engine will run "satisfactorily" in this range:
1972 USA Owners manual (Page 10 ... ):
For most types of driving, the pointer will hover about halfway. However, the engine will run satisfactorily when the pointer is at any position in the middle range.
TIP: Use the stock engine-drive fan. Electric fans are notorious for failing to cool the radiator in stop/go traffic. Of course an electric fan can work well, but many don't.
What is the correct temperature the engine should run at?
Primarily, this depends on the thermostat. The engine can run fine at a variety of temperatures. You can get different temp thermostats, and the coolant should stay steady at that temperature.
Datsun factory options were:
* THERMOSTAT 170 F (75.5c optional, for tropical use) * THERMOSTAT 180 F (82 c, for standard use) * THERMOSTAT 190 C (88 c, optional for winter)
These three thermostats were mainly because of the heater. 170 for hot climes so the room heater won't put out much heat, 190 for cold climes so the heater puts out more heat.
180 is recommended for all street cars, it will keep the oil at optimum temperature (oil runs about 20 degrees hotter than the coolant). A guy at the oil company told me 180 is ideal for the oil working the best. He went through training for Mobile I think it was and they were formulating oil for 200 degrees, which works out to be 20 degrees warmer than the coolant for most engines. Maybe it's changed now but it won't be colder as engines now run hotter than ever. If anyone has documentation for this please add it here.
160-degree is favored by some for drag racing as they tune the carbs for cold dense air, or for use with low octane fuel. But EFI computers don't run well at cold temps nor does the oil, and cold temps mean more engine wear. Cold temps are not recommended.
But won't I make more HP with a colder thermostat?
Not if your carburetor jetting is stock -- it expects warmer less dense air. And when you floor the accelerator pedal, the air cleaner hot air duct opens up letting only cooler air in, and the stock Hitachi compensates via the power valve. Those clever Datsun engineers had it covered.
Many cars use a 195 F degree thermostat along with a 14 lb. radiator cap to raise the boiling point. A radiator is more efficient at higher temperatures, because the temperature differential to the air will be greater, thus shedding heat faster. In turn airflow can be reduced which increases aerodynamics.
After the thermostat, the radiator is the next factor. If your temp. stays steady except on hot summer days (which is normal), you can use a bit larger replacement radiator and it will stay steady even during temperature peaks. Use either a new unit, rebuilt unit, or a good used unit from a B210 or B310, which are larger than the 1200 radiator.
See Radiator.
Thermostat Types
Newer Type -- advanced type with 'jiggle' valve. The jiggle valve is used to "shorten the warm up period" (Nissan Service Bulletin No. 188 Introduction of New Datsun B210, 1973).
The 1969 L16 service bulletin says: "fitted with a jiggle valve to improve defrosting performance"
Thermostat Testing
Test it in a pot of water, heated on the stove, with a cooking thermometer.
- Notice at what temperature the thermostat opens
- Check that it opens at least 8mm by using a 8mm-wide screwdriver
Thermostat Part Numbers
Cooling Thermostat. $7-$16
Nissan Part Numbers for B10/B110/B210/B310 180F (82C) 21200-P7901 $19 USD 190F (88C) 21200-P7906 $19 USD (optional, winter)
Buy at http://www.rockauto.com
There are many slight variations from different manufacturers:
Gaskets
There are various gaskets.
NOTE: 4-bolt gaskets work on a 2-bolt housings.
2-bolt: 11062-18000 GASKET-WATER OUTLET 3-bolt: 11062-M3001 GASKET-WATER OUTLET 4-bolt: 11062-H7201 GASKET-WATER OUTLET
CORTECO 111451
Fel-Pro 352981
Victor Reinz C20116
Gates 33644
Stant 25168
Stant 25113 universal gasket Gates 33646 universal gasketFel-Pro 25608 Victor Reinz C26075
For standard B110 180-degree thermostat:
Rockauto.com * STANT 13858 with jiggle pin 180 degree (82C) * STANT 32118 with jiggle pin 180 degree (82C) * STANT SuperStat 45858 with jiggle pin * GATES 33478 with jiggle pin * GATES 33478S Premium with jiggle pin * BECK/ARNLEY 1430685 * BECK/ARNLEY 1435685 Fail-Safe * MOTORAD 2041180 * MOTORAD 7241180 Fail-Safe * Prestone 391-180 * Prestone 752-180 * ACDELCO 12T25D (19114482) * ACDELCO 12TP10D {#19114402} * GATES 33478 * GATES 33478S Superstat * STANT 45858 Superstat
Dimensions: * 2 1/8" diameter * 29/32" high hot side x 13/16" high cold side Stant 13858![]()
192 degree (use in cold climates) * STANT 13859 with Jiggle Pin * STANT 45859 Superstat * GATES 33479 with Jiggle Pin * GATES 33479S Superstat * BECK/ARNLEY 1430686 * ACDELCO 12T25E
160 degree (use in hot climates) * BECK/ARNLEY 1430684 * MOTORAD 241160
Honda 1994-1996 PASSPORT ISUZU 1989-1994 AMIGO, 1992 IMPULSE, 1981 I-MARK, 1981-1995 PICKUP, 1985-1989 I-MARK, 1991-1997 RODEO, 1988-1990 IMPULSE, 1984-1991 TROOPERDatsun/Nissan 1971-1973 1200 1974-1978 B210 1979-1982 210 1974 260Z 1975-1978 280Z 1979-1982 280ZX 1971-1972 521 Pickup 1972-1979 620 Pickup 1980-1986 720 PICKUP 1986-1989 D21 Pickup 1987 Pathfinder 1976-1978 F10 1979-1982 310 1983 Pulsar 1983-1989 Pulsar NX 1971-1973 Datsun 510 1973-1976 610 1974-1977 710 1978-1981 510 1977-1988 200SX 1977-1981 810 1982-1984 Maxima 1982-1988 Sentra 1982-1989 Stanza 1987-1988 Van
Thermostat Housing
Nissan calls the thermostat housing the "Water Outlet".
