Turn signal switch
Revision as of 05:36, 31 October 2023; view current revision
TS/Beam Switch Assembly (dimmer switch, flicker switch) is a key part of the Turn Signals system.
Connects To
The turn signal switch connects to:
  • Steering Column
  • Steering wheel. Specifically the pins on the bottom of the steering wheel hub cancel the turn signals when the wheel is turned
  • Horn pad on the steering wheel, via the copper spring-action contact
174_579e94be04978.jpgHorn Button
19645.jpgAlbum 19645
The TS/Beam Switch mounts on the Steering Column, just behind the Steering wheel. It contains the turn signal lever stalk, cancelling mechanism and the Horn contact wiring.
Steering wheel cancelling pins
174_5d6c7c27dacc3.jpgPost 492433
Standard switch
SWITCH COMP-turn signal & dimmer
25540-H1007  B110 STD, B120 -7803 $155.78 USD
* superceded 25540-H1006
25540-H1007L B120 (BENT ARM 10 DEGREE)
25540-HG007  B120 (STRAIGHT ARM)
passing switch type
25540-H1100 SWITCH COMP-turn signal & dimmer
* OPTION DX, GL, GX
* Optional on B120 -7803
* Standard on B120 7804-
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
23134.jpgAlbum 23134 19664.jpgAlbum 19664
19662.jpgAlbum 19662 19663.jpgAlbum 19663 23135.jpgAlbum 23135 23136.jpgAlbum 23136
ディマースイッチ ウィンカースイッチ
