Sedan Grille
Revision as of 07:19, 10 May 2009; view current revision
Category: Body
Datsun 1200 Sedans were fitted with a stainless metal grille. 1200 Pickups from 1971-1977 use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Also see: Grille Overview, Badges
Original Grille
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
  • Japan market 1200s used "S" mark
  • Export market 1200s used "D" mark
Fitting
Click for full size pictures of the grille mount points:
And the eyebrow trim mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to nearly all Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit it to a Coupe.
  1. Fit one L-shaped bracket to center top of front body
  2. Drill four holes in radiator support
  3. Fit two thin brackets to back of sedan grille
  4. Screw grille with sheet loops to front of car
  5. Fit the headlight surrounds
    coupe and late ute are missing the outer bracket:
    I believe all core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
    96706-B0700 GROMMET for screw
  • Grille (1-3)
    62302-H1003 ASS'Y-grille, radiator Sedan (exc. GX) $169.65 USD
    62302-H2300 ASS'Y-grille, radiator Sedan GX
  • 96706-B0700 SCREW-grommet (4 total) $1.00 USD
    85-10410-4 SCREW (4 total)
  • Center Badge (4-7)
    62312-H1026 SET-ORNAMENT, radiator grille ['S']
    62312-H1626 SET-ORNAMENT, radiator grille ['D']
    • 89-15434-1 WASHER-plain (2)
    • 89-15134-1 WASHER-lock (2)
    • 89-11104-1 NUT (2)
  • Grille side emblem (8-13)
  • Eyebrow Trim (head lamp Rim) (14-19)
    62320-H1002 ASS'Y-RIM, head lamp (R.H)
    62321-H1002 ASS'Y-RIM, head lamp (L.H)
    • 85-30412-9 Screw: Stainless outside (1 per side)
      96706-B0700 SCREW-grommet [square-hole wedgie](2 per side)
    • 85-30412-9 SCREW (1 per side)
      89-64104-4 NUT-spring (1 per side)
  • Surround Trim (20-25)
    62322-H1001 SURROUND-radiator grille, upper
    • 85-40410-12 SCREW (6 needed)
    62323-H1001 SURROUND-radiator grille, lower
    • 85-40410-9 SCREW (10 needed)
    62324-H1051 SURROUND-radiator grille, side with rubber (R.H)
    • 4 screws, unlisted in catalog
    62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side)
    62325-H1051 SURROUND-radiator grille, side with rubber (L.H)
1972 Minor Facelift
The 1972 JDM facelift introduced a new grille for sedans.
Retro-fitted to newer Sunny Truck:
Emblems
Late JDM intricate "S" grille emblem
