Datsun 1200 uses a traditional standard type rotary electric Windshield wiper motor.
Also see:
- Wipers for linkage, blades & inserts
- Kangaroo Bag for Washer & Pump
- Wiper Motor Repair
- Wiper Motor Upgrades
- Wiper Wiring
As with the rest of the wiper system, Wiper Motor for RHD and LHD are reversed. RHD models have the wiper motor on left side, just below the left bonnet hinge.
LHD 1200s have the wiper motor just below the right hood hinge.
Nissan 28810-H1601,28810-H1602,B8810-H1900,28810-H1600 ASSY-MOTOR (ISO THREAD)
- Hollander 160 (1971-1972)
- Hollander 1061 (1973)
- Crown remanufactured No. 431205 - $80.99 USD
Wiper motor fits Datsun 1200 only, both cars and B210 pickup. B210 wiper *may* fit but the electrical connectors are different (round vs. rectangular)
Intermittent Wipers
Some B310s had intermittent wipers. Apparently the motor is the same, but there is an "amplifier" box. Perhaps it can be adapted to the 1200.
1978-up B120
Mid-model utes and later Sunny Truck came with intermittent wipers. This can a direct bolt in except for needing to wire up one connector. You would need the amplifier and wiper switch, and sub harness:
- 25260-G1060 SWITCH ASSY-WIPER F/INTMT WIPER
- 7804-8109 OPTION
- 8110- STANDARD EQUIPMENT
- 28890-B8060 AMP-INTERMITTENT WIPER 7804-
- 28890-B8060 USA 620 AMP UNIT-INTERMITENT WIPER DX 0778-
- 08513-30812 SCREW
- WIPER SUB HARNESS
- 24018-B9300 USA 620 HARNESS-WIPER DX 0778-
- 25260-B9300 USA 620 COMP-SWITCH,WIPER (INTERMITENT DX 0778- $35.80 USD
- Possibly may fit 1200 dash?
Does this work???
- Remove the regular wiper switch
- Install the new wiper switch and connect it to the stock harness
- Screw the AMP to the steering post with its SUB HARNESS
- Connect AMP harness to SWITCH
- Create the new connector (in Red circle of wiring diagram) and plug it in
- Connect Blue/Red (LR) wire to fuse box 'W' terminal
- Connect Black wire to an available earth
- Connect Yellow wire to the original stock SWITCH connector Y wire
